K factors - Multiple Materials
AbeFM
(@abefm)
Miembro
I suppose I'm technically asking for my Chimera+ based printer, but I imagine the same holds for the MMU (which isn't working well enough for fine tuning yet).....:
How do you set the K-factor if you have different filaments/extruders? One set by the filament code in the header won't carry through for each change.
Is there a way to handle different compressibilities between two materials? Some slicers have filament change code, and you could add it there....
I maintain an informal list of San Diego, CA 3D printing enthusiasts. PM me for details. If you include a contact email and I can add you to the informal mailing list.
Respondido : 27/09/2018 12:55 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: K factors - Multiple Materials
If you use linear advance and have the facility for "Filament G-code" then the K values should be placed there and the instruction issued on tool change.
Peter
Respondido : 27/09/2018 11:01 am
AbeFM
(@abefm)
Miembro
So they are. Thank you, Sir Peter.
Respondido : 30/09/2018 1:07 am
