IR sensor registers 0 as filament backs out
What is the point of backing out when loading filament? That's where 100% of my problem with the MMU2S can be found. When it does, the filament always slips because of the tapered end. I have lost literal days on this. I'm begging for help. I have tried both calibrating the sensor to be super sensitive to change and calibrating the sensor to change when the diameter of the filament is at least 1.75mm. Nothing has helped and I'm losing my sanity.
Opublikowany : 21/12/2022 8:00 am
