IR Sensor issue after MMU2 install
ATM_Machine
(@atm_machine)
Just installed MMU2S to i3 MK3S. All is well except filament present not showing on LCD. I never see a 1 or 0, only a ?
Things I've tried:
reinstalling firmware on MMU2 and MK3S
new IR sensor
double checked connection in box
checked electrical continuity of wire harness from IR sensor to box
Any ideas would be appreciated.
thanks,
Napsal : 15/03/2020 10:52 pm
RE: IR Sensor issue after MMU2 install
Posted by: @public-mlf
Things I've tried:
new IR sensor
thanks,
IR-Sensor activated in the lcd? If not, you see only n/a.
Napsal : 16/03/2020 12:59 am
ATM_Machine
(@atm_machine)
I have tried activating and deactivating. The display on shows "?" next to the "F"
thanks
Napsal : 16/03/2020 4:06 pm
vintagepc
(@vintagepc)
It will show "?" until a filament is actually loaded. Something has to happen for the printer to know which filament it is currently on, such as a T-code in a print or a manual load to nozzle from the menu. MMU to printer comms is somewhat limited, changing the selected filament from the MMU itself using the buttons is not enough.
Napsal : 17/03/2020 12:06 pm
Which firmware have you installed? This one: https://cdn.prusa3d.com/downloads/firmware/prusa3d_fw_3_8_1_MK3S_1_0_6_MMU2S.zip
The IR sensor should show the value 0 in the display even if it is disconnected.
Napsal : 17/03/2020 2:26 pm
rw
 rw
(@rw)
Hi you got a new sensor with the kit and you have the old sensor. Swap them and see if that fixes it.
Napsal : 17/03/2020 5:36 pm
