How-to to customize the ramming and speed settings for adjusting filament ends forming
michael.h56
(@michael-h56)
Hello everybody.
The use of different filament manufacturers leads to different deformation of the filament ends, especially when using the MMU2.
Therefore, I would like a how-to to customize the ramming and speed settings for adjusting this issue.
Is there any empirical values ​​on how to change the settings of the filament feeder in order to suppress, for example, a thickening of the filament tip or a lengthened filament tip?
LG
Michael: P
Veröffentlicht : 08/11/2018 8:27 am
michael.r28
(@michael-r28)
RE: How-to to customize the ramming and speed settings for adjusting filament ends forming
You are absolutely right: There are so many parameters for the multi material unit (ramming, cooling moves (velocity) ) and PRUSA left no description for us.
I spent one day to get a color change with a soluble material. At the end the day I could print but with a 50% failure rate!
Veröffentlicht : 18/06/2019 12:54 pm
stoofer
(@stoofer)
You have a lot of control over the tip via temperature, which you already have per-filament setting for in Prusa Slic3r, so try these first.  Basically, try to go as hot as you can (for a thinner tip) but don't go so hot you get stringing.
Veröffentlicht : 19/06/2019 8:13 am
