How about some drawings or photos of the MMU2S setup?
wayne.s6
(@wayne-s6)
I got my MMU2 a few months ago and it is still in the box waiting for the latest "S" mod parts to arrive.
Has anyone seen a PRUSA drawing, video or photos of the suggested layout with their filament untangler installed?
That way I can prep a new setup before the parts get in.
Wayne
Napsal : 02/03/2019 7:54 pm
wayne.s6
(@wayne-s6)
Re: How about some drawings or photos of the MMU2S setup?
Lots of views but no answers, someone must have a photo of the new setup?
Napsal : 05/03/2019 3:07 pm
FaultyLine
(@faultyline)
+1!
Napsal : 10/03/2019 8:09 am
Martin_au
(@martin_au)
I'm not going to rustle up pictures, but this mod:
https://www.thingiverse.com/thing:3442367
Shows what's going on (though the normal setup has the idler door and lever as one piece).
The sensor is mounted in the top of the tower. As the door opens slightly to let filament through, the lever activates the sensor. The original cable for the sensor is run up inside the tower, then out the back and to the sensor.
Napsal : 12/03/2019 1:29 am
FaultyLine
(@faultyline)
Very nice! Should we be concerned that you've already had to modify the new "S" version to make it better? 😆
Napsal : 12/03/2019 4:05 am
Martin_au
(@martin_au)
Not at all.
I modify lots of parts to make them more suited to my needs. Even a very good design can often be improved with another set of eyes taking a look. That's the nice thing about open source designs.
Napsal : 12/03/2019 7:01 am
AbeFM
(@abefm)
Do you have any other pictures? I'm still not sure how it works, at all. Is there a microswitch in the chimney? Does it toggle the mk3S optical paddle switch?
I think it's the only way to really do filament switching... knowing when it got there.
I maintain an informal list of San Diego, CA 3D printing enthusiasts. PM me for details. If you include a contact email and I can add you to the informal mailing list.
Napsal : 10/04/2019 10:16 pm
jonasrh
(@jonasrh)
I don't have any pictures, but they are using an ir sensor that get triggered by the arm on the idler door.
https://github.com/prusa3d/MKxS-IR-sensor
Napsal : 11/04/2019 3:20 pm
markus.i2
(@markus-i2)
If you're looking for the setuo with the filament "untangler" (a.k.a. Filament Buffer), check the MMU2s Printing Handbook https://prusa3d.com/downloads/manual/prusa3d_manual_mmu2s_eng_1_00.pdf on page 7.
If you want my personal and biased opinion on this: it may be a nice way to set up the MMU with minimal space and at low cost - but it's a PITA to fiddle the fialment through the buffer. The buffer at minifactory https://www.myminifactory.com/object/3d-print-filament-buffer-for-original-prusa-i3-multi-material-upgrade-85794 looks somewhat better, but if you can do your own setup (e.g. stacking the filament storage with the buffer above or below the printer), you'll probably have less hassle.
I'm likely not qualified for a final opinon, as I'm still struggling to get my MMU to run again after messing it up while looking for a filament loading problem which, in the end, turned out to be a loose screw on the extruder Bondetch gears 😳
Napsal : 16/04/2019 7:31 pm
toaf
 toaf
(@toaf)
took me forever to find this last night. silly me it was in the printed manual
Napsal : 16/04/2019 8:25 pm
ScottishColin
(@scottishcolin)
Here's mine out in the wild (upgraded from MMU2 to MMU2S). Not as neat and tidy as the manual but it does show you can pretty much place things as you wish, not just as the manual says.
As others have said, getting the filament fed through the buffer is a PITA - I got a long thin strip of wood and put it inside the appropriate buffer slice to ensure the filament came out the right side.
So far, I've noticed that the IR sensor was a pain to set up but seems (touch wood) OK now and that the purge block doesn't get big blobs building up like I used to get with my MMU2.
Bed levelling is awesomely fast too with the new firmware.
Napsal : 17/04/2019 11:43 am
