filament loads and immediately unloads
Not much else to say here, but:
- I use the main screen to run the "Load filament" command
- The filament begins to load (is correctly pulled through the rollers)
- filament hits the sensor and immediately retracts back out of the rollers
- Printer acts as if filament load worked, no error message
So far in troubleshooting, I tried to clean out the hole near the sensor, but it had no effect. I also just verified that I have the most up to date firmware.
Had no problems with this on my last print a month ago.
Publié : 30/03/2021 9:25 pm
