extrudor stops extruding filament halfway through a longer printing session.
Jasper Lisabeth
(@jasper-lisabeth)
The extrudor stops extruding filament about halfway through a longer printing session.
the piece i want to print has a printing time of 5h18. The first hour or two seem to go normal. when i come check the print about halfway through, i see the printer following the right track to print this piece, only it doesn't extrude the filament anymore.
I've tried printing the same part twice, 2 weeks apart, and i see that the printer stops extruding the filament at the exact same layer.
The day before, i had a smaller piece to print, with a printing time of 30min. This seems to go normal, only longer prints of multiple hours are giving me problems.
Opublikowany : 09/04/2021 11:20 am
RE: extrudor stops extruding filament halfway through a longer printing session.
What layer height are you using? A higher layer height can be easier to print. Please save your current  3MF project file, zip it up, and attach it to a reply here so we can see your part & settings and give better recommendations.
Opublikowany : 09/04/2021 2:18 pm
Jasper Lisabeth
(@jasper-lisabeth)
I'm using a layer height of 0.15.
I'll attach the zipped file of the piece i want to print with its settings.
R25 351 R90 P
Opublikowany : 12/04/2021 6:26 am
