Conditional GCode for toolchanges
Hi Everyone,
I wanted to control the temperature better during the toolchanges between filaments of different printing temperatures. For example, this conditional code would super helpful. In essence, what I am trying to do is purge material at higher temp, then switch to the next tool's printing temperature after purging. Does anyone know how I would be able to do this in Prusa slicer via toolchange / filament specific GCodes?
Better said, in my 'pseudocode'
Fact: Tool 1 printing temperature is > Tool 2 printing temperaure.
CODE:
If TOOLCHANGE = T1 to T2
Finish wipe tower
Perform Tool Change
Maintain T1 Temperature
Purge on wipe tower
Change to T2 Temperature
Resume Print
If Toolchange = T2 to T1
Finish wipe tower
perform tool change
Change to T1 Temperature and wait
Purge on wipe tower
Resume print
What I have been doing is going through and manually changing everything, a big pain.. any help is much appreciated!
Tim
RE: Conditional GCode for toolchanges
Hi Everyone,
CODE:
Finish wipe tower
Perform Tool Change
Purge on wipe tower
Resume Print
Finish wipe tower
perform tool change
Purge on wipe tower
Resume print
Tim
Maybe this macro will help you. I use it in Prusaslicer for multi-material prints.
works reliably and flawlessly 👍
I keep receiving this error-- see the attached photo.
Any idea?
Cheers,
Tim
I copied the link to the python file in the post-processing scripts section under Print Settings
