Assign extruder to specific supports.
I'm new to multi material but everything has been straightforward until now. After slicing a model I realize the supports for one of the models is assigned by default to the other extruder. This is causing unnecessary wasted filament on a wipe tower when it's not needed. I just want the one extruder to be the same for the model and its supports. Same for the other model, using the second extruder, model and supports using the same extruder. Sorry if this is a newb question, just can't find anything on it.
Opublikowany : 21/02/2023 9:53 am
RE: Assign extruder to specific supports.
I'm also struggling with this issue. Every time I make a new model I have to edit all the models assigned by default. This is quite inconvenient.
Opublikowany : 24/06/2024 7:39 am
