1.42.0 Wipe into Infill Setting Moved to Where?
I cannot find the Wipe into Infill setting in 1.42.0. In the older versions, you right clicked the object and the selection to use or not use was there, but no longer.
Any ideas?
Opublikowany : 07/05/2019 3:42 am
Topic starter
answered:
RE: 1.42.0 Wipe into Infill Setting Moved to Where?
Found it. Right click on the object and select Extruders. On the right hand side, extruders will appear under the object name. Below that, you will see a checkbox for Wipe into this object's infill and Wipe into this object. Select Wipe into this object's infill.
You have to do this for every single object you print, every time. I wish I could make it the default and then deselect it for objects I do not want it on.
Opublikowany : 07/05/2019 3:53 am
2 ludzie polubili
