X-Axis Crashes
When printing mmu2 models sliced in Slic3R I'm getting a crash when it does the two plate length nozzle priming lines. On the first line, starting at home and proceeding right across the front of the plate it usually starts deploying plastic at about the halfway mark. In the crash scenario it suddenly accelerates at the halfway point and drives into the far right end, skipping belt teeth. After the crash it doesn't print the second print line (the one moving from right to left) and proceedes with the print as normal. The print appears to be correct plate position regardless of the crash (not 100% sure on this point though).
This doesn't seem to be repeatable with a given gcode file i.e. I can run the same gcode 2x and one time it'll crash and one time it won't.
Is this a known issue?
I'm running the latest FWs (mk3 / mmu2) and latest version of Slic3r
