Which Soluble Filament are you using with the MMU?
MikiCab
(@mikicab)
I have the MMU working reasonably well. Which soluble filament are you using? What is your experience?
I mostly print with PLA and PETG.  I just finished my enclosure so will be starting with ABS.
Thank you in advance.
Richard
Opublikowany : 25/09/2019 7:10 pm
x50arm
(@x50arm)
RE: Which Soluble Filament are you using with the MMU?
I’m running my first roll of soluble filament now.  It is Gizmo Dorks PVA.  I’m printing it with 3D Solutech PLA right now and it seems to be going well.  I had to adjust my IR sensor and change how I’m feeding my MMU due to how soft and slippery this PVA is.
Opublikowany : 29/09/2019 2:29 pm
kursat.u
(@kursat-u)
Not tried it but this one seems iuteresting.
https://www.3dfuel.com/products/hydropro-professional-water-soluble-filament
Opublikowany : 27/01/2020 5:44 am
muddymaker
(@muddymaker)
The only luck I've had using soluble support is to use Verbatim BVOH soluble support. I've tried using e-sun's brand but had no luck whatsoever. It's just a little pricey is all.
Verbatim BVOH Soluble Support 500g
Opublikowany : 28/01/2020 4:57 am
nim108
(@nim108)
^ Wow, awesome print! Verbatim BVOH is also what I see officially supported and recommended.
Opublikowany : 28/01/2020 10:58 am
