What is "default" extruder
Steveps3
(@steveps3)
I've often wondered what is the difference between the "default" extruder and extruder 1 in PrusaSlicer? I'd like to be able to set the default extruder to be something other than 1 because I normally use the MMU printer setting even when I am only printing in a single colour. It just means that I can tell the printer which filament to use without having to mess around with the actual printer itself. So having the ability to have the default extruder to be the second extruder would be a nice feature.
Opublikowany : 07/11/2022 2:45 pm
Zoltan
(@zoltan-d-2)
Member Moderator
RE: What is "default" extruder
As far as I understand the deafult can be only one.
Opublikowany : 27/12/2022 11:32 am
