swapping back to original hot end after MM upgrade??
Angus
(@angus-3)
My Prussa i3 mk2 multimaterial upgrade hotend is failing, can i put back the hot end from the the original i3 mk2 before my upgrade?
Is it the same or will there be issues over it power output?
Thanks
Angus
Veröffentlicht : 25/11/2018 10:12 pm
GoldXD
(@goldxd)
Re: swapping back to original hot end after MM upgrade??
I switched to my old MK2 extruder (my MMU 1 hotend had a...rough go...haha) when I upgraded the MMU, it's been working fine thus far. Chat told me it was ok to.
Veröffentlicht : 25/11/2018 11:15 pm
toaf
 toaf
(@toaf)
let find a sucker to try 5 MMU1s hooked up to a mmu2 😀
Veröffentlicht : 26/11/2018 1:12 am
Slic3r might have a problem with that...
and there is no way to alow the MMUv1 extruders to free run... so they would be perpetually fighting with the mk3 extruder!
Joan
Veröffentlicht : 26/11/2018 1:55 am
toaf
 toaf
(@toaf)
party pooper 😀
Veröffentlicht : 26/11/2018 1:57 am
and imagine the real estate required for 20 rolls of filament, never mind 10 pairs of MMUv1 extruder motors and masses of PTFE Spaghetti
toaf
 toaf
(@toaf)
good gods, I didn't even think of the spools... ohh the spools...
my 5 are nice and tucked away under the printer on a rolling cart.
Veröffentlicht : 26/11/2018 2:01 am
GoldXD
(@goldxd)
I did the same when I built my MMU V2, switched back to the MK2 hotend. It worked fine for the most part, but I was having filament tip issues (to big) and I was told by chat and the discord group to switch back to the MMU V1 hotend because it has the correct heatbreak.
You could buy a MK3 heatbreak and install that to your MK2 hotend, easy fix.
Veröffentlicht : 30/11/2018 12:05 am
