Spring Steel Sheet for i3 Mk3?
TheNick
(@thenick)
Hello Guys,
I want to purchase a new Spring Steel Sheet for i3 Mk3, but I cannot find it in the online shop.
Is this actually sold as a spare part?
Opublikowany : 08/02/2019 12:47 pm
Re: Spring Steel Sheet for i3 Mk3?
You must be logged in to the online store using the account you ordered with.
Opublikowany : 08/02/2019 2:37 pm
TheNick
(@thenick)
Why it is so complicated? The problem is that the printer has been ordered from a person which is not any more in the company (it is not a private printer). I don`t have the account from which it has been ordered.
Opublikowany : 08/02/2019 3:33 pm
Contact support. I'm sure they can help you out. PM one of the Prusa guys here if all else fails.
I suspect Prusa wants to make sure their paying customers have a good supply and avoid the rush of $200 knock-off purchasers depleting inventory.
Opublikowany : 08/02/2019 4:07 pm
Robin
(@robin-4)
If your after a none Prusa sheet i used these https://www.aliexpress.com/item/Prusa-i3-Mk3-Mk52-Spring-Steel-Sheet-Heat-Bed-Platform-3D-Printer-Printing-Buildplate-For-Prusa/32945592675.html?spm=a2g0s.9042311.0.0.2f4f4c4dgoxrdR
Opublikowany : 08/02/2019 11:54 pm
imod.systems
(@imod-systems)
I'm sure if you hit them up on a live chat and tell them that you're now the owner they will set you up. They may ask for a copy of the serial number or something.
Opublikowany : 09/02/2019 1:53 am
I own 5 flexplates from buildtak. Great product that is easy to use. There are also a number of quality build plates from Aliexpress.
Example 1
Example 2
There plent of choices in this search: Search
Opublikowany : 09/02/2019 2:04 am
MikiCab
(@mikicab)
Smooth Sheet (USA)
https://shop.prusa3d.com/en/mk3-printer-parts/216-spring-steel-sheet-smooth-pei.html
Textured but not orderable yet.
https://shop.prusa3d.com/en/mk3-printer-parts/214-powder-coated-spring-steel-sheet.html
Opublikowany : 15/02/2019 5:28 am
Smooth Sheet (USA)
Most of us know that alreayd that is why we are looking for alternatives.
Opublikowany : 15/02/2019 2:58 pm
