Purge Calibration Towers
Peter L
(@peter-l)
Just posted to Thingiverse: https://www.thingiverse.com/thing:3102486 .
This is a set of purge calibration towers. They print layers which alternate between two materials, sandwiched between single-material layers, allowing you to easily see if your purge setting is sufficient to prevent color bleeding.
There's four different towers, so you can test the purge settings for 2, 3, 4, or 5 different materials in one print. Every possible pair of materials is tested (i.e. the 3-material tower tests purge between materials A and B, B and C, and C and A).
Veröffentlicht : 15/09/2018 11:56 pm
toaf
 toaf
(@toaf)
Re: Purge Calibration Towers
was that the thing you where working on when I stopped by?
Veröffentlicht : 17/09/2018 4:29 am
Peter L
(@peter-l)
Yes.
Veröffentlicht : 17/09/2018 3:30 pm
colin.a3
(@colin-a3)
Every possible pair of materials is tested ?
Veröffentlicht : 18/09/2018 11:43 pm
Peter L
(@peter-l)
Yes. So if you're doing the 5-material tower, it tests:
  • 1 <-> 2
  • 2 <-> 3
  • 3 <-> 4
  • 4 <-> 5
  • 5 <-> 1
  • 1 <-> 3
  • 3 <-> 5
  • 5 <-> 2
  • 2 <-> 4
  • 4 <-> 1
  • That's every possible transition if you have five different filaments, and lets you test every box on the "Advanced Purging Volumes" matrix.
    Veröffentlicht : 19/09/2018 3:19 am
    toaf
     toaf
    (@toaf)
    the things you do for SCIENCE!!!!
    I've got about 10 10 layer tests ready for when I get my MMU. but I will try your test after i get past 25 layers.
    nothing i have done seems to allow me to use the wipe towers AND manual filament changes. i can do one, or the other.
    Veröffentlicht : 19/09/2018 3:28 am
