MMU2 moves to next Filament Location
Yngeinstn
(@yngeinstn)
On the start of every new job. It's getting quite frustrating to say the least. Anyone else having this same problem and/or come up with a solution?
thanks
Veröffentlicht : 10/09/2022 12:50 pm
JohnnyT
(@johnnyt)
RE: MMU2 moves to next Filament Location
Are all your sensor work correctly?  Menu. Support/Sensor Info.
Is your Filament sensor enable? Menu Settings/Filament Sensor
Is Spool Join off?
Good Luck, JT
Veröffentlicht : 12/09/2022 1:38 pm
Yngeinstn
(@yngeinstn)
Thank you for the suggestions. I will check them when i get home.
Veröffentlicht : 12/09/2022 1:43 pm
MileHigh3Der
(@milehigh3der)
I think I get why spool join would affect it, but can it have an effect even if spools don’t run out?  Mine seems to get ‘lost’ as to what it is on- the light and the selector don’t sync…
Posted by: @johnnyt
Is Spool Join off?
Good Luck, JT
Veröffentlicht : 31/10/2022 12:54 am
Yngeinstn
(@yngeinstn)
I have been having a lot of issues with the MMU2 as of late. Like you, mine gets lost like yesterday for example. I have a print set up on Filament 3 and it just sits at Filament 1 with the light blinking on Filament 3 (waiting to load)..
Veröffentlicht : 31/10/2022 12:33 pm
MileHigh3Der
(@milehigh3der)
Exactly.  And during start up, it doesn't seem to want to run a 'where am I'bang on the ends calibration.  The physical demons I can address, its the electronic ones that have me scatching my head.  It is 'inconsistent' in what it does- when I'm not changing anything.  Really infuriating because I had the physical issues largely addressed.  I have a video channel now on youtube, I'll try to post some start-up and error sequences.
Posted by: @yngeinstn
Veröffentlicht : 31/10/2022 12:59 pm
