MMU jam on unload, just above bondtech gear @ extruder
KMKMD
(@kmkmd)
Hi there,
Several times, my printer has jammed with a crooked filament retracting out of the extruder.  It hangs up just above the bondtech gear, on the chimney because of a small kink in the filament tip (see photo). The end of the filament at the bottom of the photo is the bit that is jamming.
Why, oh why is this happening? I've also had the sad luck of this occurring in the hotend PFTE tube (within the heat break) requiring tube replacement.
Thanks for any ideas!
Kevin
This topic was modified před 3 years by KMKMD
Napsal : 18/11/2022 3:21 am
bzb
 bzb
(@bzb)
RE: MMU jam on unload, just above bondtech gear @ extruder
I have the same problem, especially with PLA 😥
Napsal : 18/11/2022 12:32 pm
bzb
 bzb
(@bzb)
I solved this problem. I noticed that the filament sensor reports "0" after printing for a while. But the insertion of the filament went well (filament sensor "1"). The problem is in the bent tower of the sensor (thermal stress in the box). I printed the tower from ASA and set it up according to the procedure here: Now everything OK
Napsal : 19/11/2022 12:12 pm
