Looks like someone came up with a MMU2 clone
devilhunter
(@devilhunter)
https://twitter.com/proteadesignllc/status/987968140574257152/photo/1
More options to choose from, yay open source?
No info so far on the multiplexer board from them.
Opublikowany : 22/04/2018 11:09 pm
Albe
 Albe
(@albe)
Re: Looks like someone came up with a MMU2 clone
That dude has been working on his Selectra for a long time now so I don't think it is a clone of the MMU2. Good to have options.
Opublikowany : 23/04/2018 10:26 am
eric.d14
(@eric-d14)
Yeah look back at the earlier tweets from that account and you'll see that Josef just might be aware of this design. 😉
Who can say which inspired which?
https://twitter.com/proteadesignllc/status/964029524194160640
That said, I actually like the following idea even more, as it keeps the motorized filament channel of the MMU 2.0 (which avoids possible jamming in a coupler) and uses a roller mounted on the guide to actuate the proper idler automatically without needing a third motor driving a giant cylinder.
Opublikowany : 23/04/2018 11:49 pm
Peter L
(@peter-l)
I, too, was wondering why the MMU2 uses a separate motor to select which filament is engaged instead of just having a mechanism on the selector.
Then I realized that the Prusa design allows the MMU drive motor to completely disengage once the extruder motor grabs the filament and starts feeding. The MMU's drive motor doesn't need to keep in sync with the extruder, avoiding a certain amount of software complexity and any issues that might come up if the two motors aren't perfectly calibrated to each other.
Opublikowany : 24/04/2018 10:49 pm
eric.d14
(@eric-d14)
That's a good point, also now that I think of it, keeping the feed & selector functions independent would be required for however the filament trimming feature will work. (likely a blade on either side of the carriage that would cut off any protruding filament as it moves into position)
Opublikowany : 25/04/2018 5:44 am
Crunch
(@crunch)
Posted that back in May before the kickstarter https://shop.prusa3d.com/forum/general-discussion-announcements-and-releases-f53/mmu2-0-video-anytime-soon-anyone--t17546-s10.html
One note the purge block is very small on all the videos
Also the price is quite reasonable around $110 usd for the kit
The Latest Firmware can be found here https://github.com/prusa3d/Prusa-Firmware/releases
Open Firmware Issues https://github.com/prusa3d/Prusa-Firmware/issues
Opublikowany : 20/10/2018 9:48 pm
