Filament Settings / DAS Filament PLA ?
BeNe
 BeNe
(@bene)
i still try to get my MMU2s running well. But i have problems with my  filament settings. I´m using PLA from DAS Filament which is a good brand and working well without color change. But it´s get stuck in the MMU2 itself or it is unable to inject into the hot end.
I tried to get as cold as possible. This picture was made with 185°C on the hotend. It´s not possible to print with less than 185°C because the layers wont stick good together. Are there any options to adjust ? Read something about Ramming, dribbling...but i´m not sure where to start.
Maybe someone already has a working config for "DAS Filament" PLA ?
Thanks
Este debate ha sido modificado el hace 7 years por BeNe
Respondido : 21/09/2019 7:15 pm
Lichtjaeger
(@lichtjaeger)
RE: Filament Settings / DAS Filament PLA ?
You can try mine. Works great for me.
Attachment removed
Respondido : 22/09/2019 12:20 am
1 les gusta
BeNe
 BeNe
(@bene)
Thanks for your configuration. I will give it a try 👍
Respondido : 22/09/2019 11:49 am
Pixel
(@pixel)
is the blade on your selector positioned correctly so it can cut off the stringing when it moves back to this extruder?
i never looked at my filament tips and never had a problem with them but i see a bunch of thin stringing piling up under the selector as the blade is cutting it off.
Respondido : 23/09/2019 8:15 am
BeNe
 BeNe
(@bene)
@lichtjaeger
I had no luck with your settings:
@pixel
Yes the blade works fine. But in this case the filament won´t come out from the extruder.
Or, the string is that long that it´s get cut but a litte part is still in the tube/bowden down to the extruder.
Respondido : 23/09/2019 5:41 pm
