3MF and multicolour
Stephen Winnall
(@stephen-winnall)
3MF and multicolour
I have just managed to print my first non-test multicolour object using my MK3S and its MMU2S. I'm still a noob, but I'm pleasantly surprised how easy it was.
I designed the object (a mounting plate for a UniFi doorbell with my family name underneath it) with Fusion 360 version 2.0.13168 with two bodies (the background frame and the name plate). I made both bodies visible and exported them as a 3MF file, which I imported into PrusaSlicer version 2.4.2+x64 configured as a printer with MMU2S support.
Importing into PrusaSlicer results in a strange message, which I suspect is an error:
My Fusion 360 is configured to use millimetres, so I don't know why this message appears. I answer "No". If you answer "Yes", PrusaSlicer tries to convert the units from inches to millimetres, which results in objects that are far too small (2.54 or 25.4 times - not sure which).
I then get the following message:
I choose yes. PrusaSlicer then allows you to assign filaments of whatever colours you have configured to the bodies in your 3MF file:
Generate the G-code, load it into your trusty Prusa, and collect the result six hours later:
I suppose I could have chosen more exciting colours than black and white, but the principle holds 😄
Veröffentlicht : 16/06/2022 8:21 pm
