Step 16 tube slides around
Hello,
The top brass tube on the selector, as seen in step 16 of the assembly instructions, doesn't stay in the selector. It moves freely back and forth along the shaft. It doesn't impact the print any as the selector just moves over it, and it will slide into and then out of the selector.
I'm just wondering if there is anything I can do to get it to stay in there. I'm thinking maybe I could use some sandpaper to rough up the tube then put a little CA glue on there, and slide it in.
Any reason I can't do that?
Thanks
Rick
Postato : 10/07/2022 12:03 am
RE: Step 16 tube slides around
i have the same problem with the top tube. Have you sucessfully tested your idea?
Postato : 02/08/2022 1:29 pm
