Purge Block with Soluable?
It seems the tool changes are not working properley while using soluble supports. Thoughts?
The image below shows it skipping the pva load/unload and the blues load.
Opublikowany : 25/12/2018 9:13 pm
Re: Purge Block with Soluable?
Were you able to get this going? I just started printing with PVA and got it working.
Make sure you set the top drop down "printer settings" to the soluble interface one.
On printer settings > multiple Extrudes make sure you set the "support material/ raft interface extruder to the one with the Soluable.
Opublikowany : 30/12/2018 8:50 pm
