Pulleys lost grip
MahZeh
(@mahzeh)
Pulleys lost grip
Hi All,
after I got the MMU2 working it did its job for about 2 weeks almost flawlessly (About 12h per day, 1k changes)
Now I got issues with Channel 1 and 3. Specifically 3 is not even loading the filament anymore
After quite some trial and error I had a closer look at the pulleys and discovered there is soo much
rubbed of parts from the filament that the pulley seemed to have lost all grip.
I tried to clean it with a toothbrush but it didn´t work at all
Does anybody have a good suggestion on how to get them clean and working again?
Is there any maintenance guidance for the MMU unit you follow?
Napsal : 23/11/2018 12:51 am
JuanCholo
(@juancholo)
Re: Pulleys lost grip
if you open up the hinged cover then you could clean it with a brass brush. brass is a softer metal so it should not damage the pulleys.
“One does not simply use a picture as signature on Prusa forums”
Napsal : 23/11/2018 2:21 am
PJR
 PJR
(@pjr)
Antient Member Moderator
And to help prevent this happening, set the initial load to 19 mm/s so that the speed of the two drives is matched.
I use a pen knife to clean out the gears, individually and very carefully.
Peter
Napsal : 23/11/2018 10:10 am
MahZeh
(@mahzeh)
Thank you both
I will try both solutions and report back
It was pretty late last night I need to take some time to focus on this
Hope to be back operational again soon, as I like the MMU2 a lot 🙂
Napsal : 23/11/2018 12:35 pm
MahZeh
(@mahzeh)
Uffff
Seems I lost channel 3 😕
After cleaning the pulleys I checked if there is any friction in the system.
Everything is smooth just for channel 3 I can´t move the filament through the selector 😳
When I push filement from the extruder site into channel 3 down to the white tubes, there is no friction.
Do I push filament after the pulley into the selector, no friction either. When I push it up to the pulley, no friction
Just when I try to push it from spool holder to selector in 80% I can´t even force it into the selector manually
I disassembled the selector and checked the the path. The little white tube before the selector for channel 3 looks
like any other tube
It looks like this causes also the rubbed of parts of filament on pulley 3
I have no further idea, any help is highly welcome
Napsal : 24/11/2018 1:45 am
JuanCholo
(@juancholo)
did the pulley set screw come loose and it is just spinning on the shaft
does the bearing in the selector assembly look damaged is it still centered on the pulley teeth.
Napsal : 24/11/2018 2:05 am
MahZeh
(@mahzeh)
The pulley is rock solid, also the bearing is not damaged
Loooks like the calibration is not spot on for channel 3 anymore
I can pull manually any filament through the selector to the orange tube
Just for channel 3 it get stuck at the selector. Do I pull it from the extruder side it goes smooth
also from channel 3
When I feel it hits the selector, I switch off the printer and turn the rod of the selector 10-15°,
then I can pull it in without any resitance
As it is working for channel 1,2,4,5 how can I calibrate it for channel 3 ?
Napsal : 24/11/2018 2:25 am
JuanCholo
(@juancholo)
the only thing i can think of is the selector is binding on something around #3
move the selector to 1 or 5 and look around 3 and see if something looks wrong.
Napsal : 24/11/2018 5:08 am
JuanCholo
(@juancholo)
see if any of the 3mm bolts are loose on the threaded nut or the motor body.
Napsal : 24/11/2018 6:32 pm
MahZeh
(@mahzeh)
After one day to calm down, I disassembled the unit 😮
Indeed one of the screws for the lead screw nut of the slector was not screwed into the nut (Step 15 2nd picture)
Looks like the thread of the nut was damaged. I put a new one in
Not sure if this was the issue as the screw was not really loose and it worked for more than 1k changes as mentioned in my opening post
Testing now :geek:
Napsal : 25/11/2018 2:50 pm
JuanCholo
(@juancholo)
i toyed with the idea of using thread lock on the hex and square nuts since over time i have had a few come loose on mk2s and the mk3 before mmu2 conversion. the vibration of the machine combined with heating and cooling cycles can start to back out a bolt.
Napsal : 25/11/2018 8:56 pm
MahZeh
(@mahzeh)
OK, looks like I´m back in the multi color game :mrgreen:
The print took about 6h and involved about 200 color changes
Thus I feel comfortable to start my prints (2 colors, about 140 changes; 12h) again
Thank you very much first of all for the support I received in the forum, specifically daniel.a6
What was the root cause?
I think it was not the not screwed in M3x10 (Instruction step 18, picture 2+3)
Once I re-assembled the unit after changing the nut with a new one (Instruction step 15, picture 2),
the channel not working anymore was 4 instead of channel 3 before re-assembly 😯
The observation was the same. Filament could be introduced from the hotend direction without any issue.
When I tried from the spool holder end there was no chance. It looked like the channel (3 first, 4 after reasembly)
was slightly misaligned thus the filament got stuck at the selector or went into any direction but the selector itself.
By chance I noticed I could easyly introduce the filament opening the pulley body and start from after the pulley.
I assume it was a misalignment of the pulleys itself. Even if it worked for more than 1k changes over several weeks
and the pulley screws were not loose.
After repeating step 11 pulley adjustment very carefully several times (<0.25 mm changes 😳 ), getting the right tension on the spring screws (instruction step 34) and re-calibrating the filament length very carefully.... it worked
I like tinkering around with things not working, but I´m under "pressure" to get about 20 prints done before 6th of December.
Thus this was a frustrating exercise to loose about a week. Hope the lessons learned will be usefull for somebody else
Napsal : 26/11/2018 8:55 pm
JuanCholo
(@juancholo)
we try, it is so hard to diagnose something through texts and a few photos. i had one pulley walk a little and i went and re-adjusted and re-tightened it.
everything on the machine is basically going through heat cycles, hot/cold, expand/contract. things that were tight get loose. usually before i start up i kind of check over the machine and check some areas with an allen key.
i had my MK3 frame get loose twice before i thread locked those 3mm Button head bolts, even when i cranked them down they would just get lose.
Napsal : 26/11/2018 9:17 pm
EddyMI3D
(@eddymi3d)
Peter
Hello Peter!
I've got my MMU2 last Friday 😎
But where do I set this initial load speeds? Either I'm blind or they are very well hidden.
Thanks a lot!
Napsal : 02/12/2018 8:41 am
PJR
 PJR
(@pjr)
Slic3r, Filament settings tab, select "Advanced". The field label is "Loading speed at the start" and the default value is 3.
You will have to set this for all your filaments.
Peter
Napsal : 02/12/2018 10:50 am
EddyMI3D
(@eddymi3d)
Thanks a lot! 😎
Napsal : 02/12/2018 11:06 am
