Print head stuck at home during print
thalassa
(@thalassa)
I have an MK3S+ that arrived assembled. I did a few test prints and it did great. I moved on to assembling the MMU2S, and started a test print. It started fine, got through a few layers of 5 different colors, but then suffered a filament load failure. After fixing it, I noticed that a firmware update was released today. I flashed the printer and the MMU. Now when I start a print, it loads filament normally, but then the print head will not move away from home once the filament starts extruding. If I don't stop the print, it just keeps building a huge blob of filament at the home location. I ran a self test and it was successful. Any idea what could be going on?
Postato : 02/03/2023 11:34 pm
Robin
(@robin)
RE: Print head stuck at home during print
You problem could be the end of the loading sequence or the beginning of the print. To rule out the gcode: post the slicer project (zip it before attaching or the forum will ignore it). Check or better recalibrate both sensors (FINDA and IR) because they cause the majority of loading/unloading problems. https://help.prusa3d.com/article/ir-filament-sensor-calibration-mmu2s_2245 and https://help.prusa3d.com/article/finda-setup-and-troubleshooting_2250
I think the most likely cause is the IR-Sensor not being triggered constantly and reliably...
Postato : 03/03/2023 10:37 am
