First print was successful!
181 tool changes with only 10 errors that I had to intervene for. Pretty solid in my opinion.
I had a bit of color bleeding, probably need to tune how much I purge.
I also had an error precisely twice where the selector had moved to the correct filament, but a red light was showing on the previous filament.
In both cases I reset the MMU2S but did not realize I could set the selector to the desired filament, so I ended up with two layers in the wrong color. You can see one of them across the eyes of the sheep.
Not bad for my first MMU print!
Attachment removed
Napsal : 27/09/2019 1:55 am
1 lidem se líbí
RE: First print was successful!
Congrats. The first successful print is a major accomplishment.
Napsal : 27/09/2019 1:15 pm
1 lidem se líbí
