Downgrade possible ? From MK3 MMU2 to MK3
bidibule
(@bidibule)
Hi all !
I'm also struggling of making my MK3 working after my MMU2 upgrade. Everything is mounted fine but can't get a Z calibration and also it seems now that I can't even upgrade the MMU2 firmware (can't see it even I'm connected using the micro-usb cable and I see MMU2: N/A in support..)
Well, my question is simple.  I have upgraded from MK3 to MK3 MMU2 but can I downgrade easily ?
I want to get back my working MK3!
Do I only need to unplugged the cable form the etsy board, remove the MMU unit and change the cover of the extruder ?  Because I have changed everything in the extruder.
Thank you very much
PS: also since last firmware update, I get the annoying message "MK3 firmware detected in a MK3S printer".  I've tried to upgrade with MK3S firmware and now it's the opposite message I get ! 'MK3s firmware detected in a MK3 printer" 🙄
Dieses Thema wurde geändert Vor 6 years von bidibule
Veröffentlicht : 13/04/2020 12:20 pm
Jody
 Jody
(@jody-2)
RE: Downgrade possible ? From MK3 MMU2 to MK3
I'm watching this one to see what steps are required to remove the MMU.
Veröffentlicht : 21/04/2020 3:57 pm
Timlindz
(@timlindz)
I too want to go back to MK3 and do away with my mmu2 upgrade how easy is it and How to do it?
Veröffentlicht : 28/11/2021 3:57 pm
Dutta
(@dutta)
RE: Downgrade possible ? From MK3S+ MMU2 to MK3S+
Could anyone redirect me to fix this issue?
Veröffentlicht : 07/05/2023 4:03 am
JustMe3D
(@justme3d)
For a downgrade, follow the MMU2 manual in reverse order. For a simple disconnect, use the search function. It's all there.
Veröffentlicht : 07/05/2023 7:25 am
