Which Hardware for Octoprint, Camera, Fan Control, and Prusa Connect???
Robin
(@robin-2)
Hey all,
New to the 3d printing world so appologies if this has been covered.
Not sure if there is documentation yet on hardware for Prusa Connect?  I couldn't find any.  I would prefer not to purchase hardware twice if it can be avoided.     Initially looking for something (Pi?) that can:
  1. Run Octoprint and/or Prusa connect.
  2. Run a camera.
  3. Control fans in printer enclosure based on temperature.
  4. Any other cool features that you might recommend?
What hardware do you recommend:
  • Pi or something else?
  • Fans?
  • Camera?
  • Thermistors?
Thanks!
Opublikowany : 29/11/2021 2:43 am
RE: Which Hardware for Octoprint, Camera, Fan Control, and Prusa Connect???
I use Pi 3B+ or Pi 4for remote control/monitoring on my machines. My enclosures don't have fans. Feels counterintuitive to create draft with fans, but then again, I don't have any and no hands-on experience. And cameras, I have Raspi cams on all printers but hardly ever use them. Instead I use Wyze cams mounted to the y-axis extrusions. I found the picture quality to be vastly superior, they're super reliable, and plug and play install.
Opublikowany : 30/11/2021 12:36 pm
Robin
(@robin-2)
Thanks. I had never heard of Wyze before.  Will keep that in mind.  Just dug out a spare Logitech C920 in my spare parts box which I forgot I had.  Will start with that.  Do you know if Pi 4 is what is being used for prusa connect?
Opublikowany : 30/11/2021 1:30 pm
Lynn
 Lynn
(@lynn)
fuchsr,  which Wyse cam do you use,  and could you post a pic.  I've been using an old Logitech camera on my X axis.  Sometimes it's a moves too much.
Opublikowany : 30/11/2021 5:13 pm
I have both Wyze Cam v2 and v3. Mounted with this mount, which fits both Mk3S and Mini. They're pricier than a Pi camera but I found them to be in a different league in terms of picture quality and reliability, plus I really like the Wyze app. For what it's worth, they also have a built-in smoke detector.
Opublikowany : 30/11/2021 7:39 pm
Lynn
 Lynn
(@lynn)
Thanks for the pic.  Not quit was I was imagining.  Mine is mounted to the x-axis carriage (found here) and moves up and down with z-motion because I was convinced I was going to print a lot of tall things, but I think I'm going to switch my mount to something similar to your version for smoother video.
Opublikowany : 30/11/2021 8:06 pm
I do have x-mounted pi cams on my printers like you do but frankly I prefer the "whole picture" view I'm getting from my Wyze cams. Plus, I couldn't figure out how to adjust the picam lens so that it stays focused for the whole length of the x-axis...
Opublikowany : 30/11/2021 8:15 pm
