What other upgrades for the mk3s+?
Taki8888
(@taki8888)
Are there any worth while upgrades for the mk3s+ aside from bear upgrade?
I saw some beefy Y motor mount that helps with noise and tension of the belt.
Not sure if there is anything to further improve print quality and reduce further noise in the X,Y,Z travel.
I added the squash feet and that helped.
Opublikowany : 01/07/2021 7:56 pm
RE: What other upgrades for the mk3s+?
There are, but the consensus is that they only make incremental improvements to anything. There are no mandatory day-one improvements required to get good prints.
Opublikowany : 01/07/2021 9:10 pm
@bobstro
What he said. With a paver and Sorbothane feet, the Mk3S is eerily quiet. The only "upgrade" I recommend is a nickel-coated copper heater block ( https://www.printedsolid.com/products/e3d-v6-nickel-plated-copper-heater-block) but even that is a nice to have.
Opublikowany : 01/07/2021 9:36 pm
Now if you want to include fun-but-unnecessary...
Opublikowany : 01/07/2021 9:43 pm
John
 John
(@john-6)
@bobstro
I’m really not sure what that is.
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
Opublikowany : 01/07/2021 10:40 pm
Taki8888
(@taki8888)
Agreed. Prints great as is. I thought there might be further improvements with upgraded printed parts for better belt alignment, etc…
Not in any hurry and enjoying.  I have it on 2” thick EVA foam + granite cutting board + squash ball feet.
I saw a cage with pikachu for motor turn indicator. Gotta have some fun. 🙂
Doing the horizontal spool holder now.
It is impressive, assemble, it just works and prints well. No regrets.
Opublikowany : 01/07/2021 11:49 pm
Posted by: @john-6
Sorry, not a good pic. The water faucet extruder visualizer is the only real upgrade I've made. I've upgraded some hotend components over time, but am overall very pleased being still at the original Mk3 configuration.
Opublikowany : 02/07/2021 1:28 am
BMet
 BMet
(@bmet)
feet and paver
Fuchsr, I assume that a paver is a flat paving stone?  Also, what size/hardness of sorbothane feet do you get the best results from?
Opublikowany : 18/08/2021 1:12 am
Yes, I used a 16 x 16 x 2 concrete paving stone from Lowe's (such as https://www.lowes.com/pd/Pavestone-16-x-16-Square-Slate/1002242514), and covered it with Plasti-Dip. The Sorbothane feet are 1'' hemisphere: https://www.amazon.com/gp/product/B005JRMYG2
EDIT: I know there are different "duro" grades for the sorbothane. I have zero idea what that means so I picked the ones in the middle of the range, and they work great.
Opublikowany : 18/08/2021 2:10 am
Higher duro are stiffer
I used 70 duro. Most are probably just fine.
Opublikowany : 18/08/2021 2:19 am
70 Duro
Have gotten good results from 70 Duro Sorbothane feet and cork feet.
Posted by: @bobstro
Opublikowany : 18/08/2021 2:44 am
