Upgrading PrusaSlicer
Buckeye Slicer
(@buckeye-slicer)
I have a MK3s and running the 3.8 firmware.  I have a raspberry Pi running and Octoprint.  I recently upgraded the slicer software to the 2.2 version.
Now when I go to print and load the gcode file into Octopi, my camera no longer works.  I have Octolapse plugin, and it was working with that, or just the regular viewing with camera.  Now with Octolapse enabled, I get an error, and can't print until I disable Octolapse in Octorpint.
Camera worked fine, until I upgraded to the new PrusaSlicer.  This is why I do not want to upgrade my printer firmware, even thought the printer keeps beeping to upgrade to new version.
Publié : 19/07/2020 7:17 am
RE: Upgrading PrusaSlicer
You can disable the firmware version beeps in the printer menu. Be aware that 3.8 has a bug that can cause layer shifts with the filament sensor enabled.
Does your camera stream using Octoprint when not printing?
Publié : 19/07/2020 3:31 pm
Buckeye Slicer
(@buckeye-slicer)
@bobstro
yes it does work when printer is not printing.  I would like to upgrade firmware also, but alot of people say they've had problems after upgrading, and if it works fine , leave it alone.  I do not want to have to recalibrate everything , reset this and reset that.  Other thing is , is it better to wait maybe 6 months or so till all problems are totally worked out with new version.  Also not sure there is anything new that is earth shaking that I need, or would make things easier.
Publié : 19/07/2020 5:36 pm
@steveandbelinda
Perhaps the Octoprint Forum can help you better in this matter. It may be due to Octolapse or your current Octoprint version. I don't think the problems are caused by the printer firmware or PS.
https://community.octoprint.org/
I hope you find something suitable to solve your problem 👍
Publié : 19/07/2020 5:52 pm
