Under extrusion after upgrade
Seite 3 / 3
JumpCut
(@jumpcut)
To be honest, I'm not 100% sure.
But, changing first layer extrusion width helped a lot. I still can't use flow 100, it is just not extruding enough, but I'm down to 120.
I also removed these three lines from the start gcode:
M221 S{if layer_height<0.075}100{else}95{endif}
{if print_settings_id=~/.*(DETAIL @MK3|QUALITY @MK3).*/}M907 E430 ; set extruder motor current{endif}
{if print_settings_id=~/.*(SPEED @MK3|DRAFT @MK3).*/}M907 E538 ; set extruder motor current{endif}
Bontech also advised me to raise the current with: M907 E550.
I set first layer speed to 30 mm.
I raised bed temp to 70 degrees C.
Posted by: @karl-herbert
Would you briefly summarize what were the most important changes that led to the current result?
Thanks!
wbr,
Karl
Diese r Beitrag wurde geändert Vor 3 years 3 mal von JumpCut
Veröffentlicht : 07/08/2022 8:04 pm
JumpCut
(@jumpcut)
RE: Under extrusion after upgrade
Also I used https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/life-adjust-z-my-way/ to calibrate Z.
Veröffentlicht : 07/08/2022 8:10 pm
👍Thanks for the feedback!
...further good success!
wbr,
Karl
Veröffentlicht : 07/08/2022 8:52 pm
Seite 3 / 3
