Tips / things to know before installing Octoprint?
megan.s
(@megan-s)
I've finally caved and will be getting a Raspberry Pi to use Octoprint.
To my understanding you don't HAVE to install directly into the Einsy board but can connect via usb. I'm assuming this means I'd just need a power source for the Pi, correct? If I'm totally wrong just let me know.
Is there anything specific I should be looking at when picking out the board or is the Raspberry Pi 3 W fine? I've noticed I can get an entire kit with a bunch of extra stuff (you can never have too many SD cards!), would that be worth it? I might be using the wifi capability so I can check in on it from work so I want that option open for me, too. And that means a webcam as well. Is there anything special I should know when picking one out, or is it fine to use the ones listed as 'approved' from Octoprint's website?
Thank you!
Posted : 11/04/2018 11:56 pm
neil.e
(@neil-e)
Re: Tips / things to know before installing Octoprint?
Buy a Raspberry Pi 3B. Don't buy the Zero W.
Make sure to turn off the "RPi" setting in the printer's menu.
Connect via USB, and plug the Raspberry Pi into the wall with a USB power adapter.
Install Octoprint from https://octoprint.org/download/ and follow their setup instructions.
That's really all there is to it.
Posted : 12/04/2018 5:57 am
termlimit
(@termlimit)
neil.e stated a solid bit of advice. Only thing I would add is get comfortable with the install and usage BEFORE adding any plugins. This allows you time to test your setup and install before adding complexity.
Posted : 12/04/2018 8:20 am
Olef
 Olef
(@olef)
Confirm, neil.e has told you all you need for a working setup.
Posted : 12/04/2018 1:38 pm
Michael K.
(@michael-k-2)
"Make sure to turn off the "RPi" setting in the printer's menu."
Is this related to the Zero W pie? Why would you turn "RPI" off?
Thx,
Michael
Posted : 12/04/2018 5:33 pm
Fotoman
(@fotoman)
Just a reminder that the standard Octoprint download does not yet support the latest Raspberry Pi 3B+. You need a nightly build from http://gnethomelinux.com/OctoPi/nightly/
Proud owner of a Mk3 that is producing very nice prints. There is room for improvement as I learn more about it, but so far I am very happy.
Posted : 12/04/2018 7:02 pm
reid.b
(@reid-b)
Thx,
Michael
RPI is the GPIO connection to a PI... if using a Pi 3 B, most would connect via the USB, and thus don't need the GPIO based connection.
Posted : 13/04/2018 12:16 am
Jim
 Jim
(@jim-11)
I installed a RasPi-0-W. I simply wanted video capability so that I could remotely monitor the progress of prints. The installation is straightforward and relatively easy using the Prusa installation instructions. The video works great through Octoprint. I have the camera mounted to the bed as most have done.
Posted : 13/04/2018 4:11 pm
neil.e
(@neil-e)
Thx,
Michael
If RPI is on then the USB connection is disabled.
Posted : 13/04/2018 8:46 pm
megan.s
(@megan-s)
Sorry I didn't respond sooner - some crazy stuff happened the past day.
Thank you all so much! I will get the 3B and go from there. 🙂 I dont plan on installing plugins until I'm familiar with it and need it. I am excited to get this going for sure.
Posted : 13/04/2018 11:08 pm
Tom
 Tom
(@tom-2)
RE: Tips / things to know before installing Octoprint?
Habe die Absicht auch mit Octoprint zu arbeiten. Habe Gehäuse gedruckt und Teile bestellt. Werde ein Pi 3 + mit Stepdown Buck Converter verwenden. Wollte die Spannung vom 24 V Netzteil , die zur Steuerungsplatine geht verwenden. Dort sollte dann der Step-Down Wandler angeschlossen werden. Jetzt bin ich mir aber nicht sicher, wo ich die 5 V Spannung an den Pi 3 B+ anschließen soll. Könnt ihr mir da helfen ? Gibt es da irgendwo einen Hinweis ? Und weiter möchte ich das Druckbett für Kamera-Aufnahmen beleuchten. Wollte dann auch von der 24 V Spannung am Netzteil mit einem Step-Down Wandler einen 12 V LED Streifen mit Spannung versehen. Bin mit der Elektronik nicht so sehr bewandert , deshalb die Frage hier im Forum. Würde mich sehr freuen wenn ich eine Antwort erhalten könnte.
Grüße aus Neu-Ulm
Thomas
Posted : 16/05/2020 2:28 pm
Posted by: @footytom
[...]Jetzt bin ich mir aber nicht sicher, wo ich die 5 V Spannung an den Pi 3 B+ anschließen soll. Könnt ihr mir da helfen ?
I wouldn't do it. The power supply on the Mk3 is close to max, and the RPi 3B+ draws considerably more power than the Zero W originally (and mistakenly) supported on the Mk3 board. While it might work, if you get into a situation where the printer is drawing maximum power and the RPi gets busy (e.g. issuing Octoprint commands while streaming video), there's a good chance either the RPi or Mk3 will not receive adequate power.
People do it. Some run for months or years without us hearing about problems (though they may still happen). It's just not recommended. Consider also that you don't want to make the tool (the RPi running Octoprint) you use to monitor a critical device (the Mk3) dependent on that device. Separate power sources are recommended.
[...] Grüße aus Neu-Ulm
Tscuss aus Boston!
Posted : 16/05/2020 6:38 pm
Tom
 Tom
(@tom-2)
RE: Tipps / Wissenswertes vor der Installation von Octoprint?
@bobstro
Danke für diese Information. Werde für Pi 3B und LED-Streifen gesonderte Stromversorgung verwenden.
Gruß aus Neu-Ulm
Thomas
This post was modified 6 years ago by Tom
Posted : 17/05/2020 10:11 am
