Skelestruder V1 in beta
JLTX
 JLTX
(@jltx)
If you are feeling adventurous and brave, you can try out my geared extruder for MK3. I have a few testers who are having good luck with it. Still in development.
https://www.thingiverse.com/thing:2845416
Opublikowany : 25/05/2018 5:16 am
Gato
 Gato
(@gato)
Re: Skelestruder V1 in beta
Not that adventurous with my printer yet to give it a try. Looks very promising. :geek:
Opublikowany : 25/05/2018 6:20 am
motocoder
(@motocoder)
Wow, this looks awesome. I'm 100% for jettisoning the Prusa design, but I'm going to wait until some instructions are available, and some user feedback.
Opublikowany : 28/05/2018 1:12 am
matthew.m34
(@matthew-m34)
Not for the faint of heart, but there is a PDF with some pictures on the Thingiverse page if you want to take a look at that.
Opublikowany : 28/05/2018 3:23 am
Steve_AU
(@steve_au)
Does this rely on having a short body motor to replace the existing extruder motor?
Opublikowany : 29/05/2018 4:18 am
JLTX
 JLTX
(@jltx)
I have a tester who is using the stock motor. He wants extreme torque. But the idea is to be able to use a much lighter motor. Either will work.
Opublikowany : 29/05/2018 5:33 am
Steve_AU
(@steve_au)
Also do you have any pictures of what it looks like finished?
Opublikowany : 29/05/2018 6:04 am
motocoder
(@motocoder)
Thanks, I completely missed that. I also found the #skelestruder room on discourse.
Opublikowany : 29/05/2018 6:10 am
metacollin
(@metacollin)
I'm coming pretty late to this game, but do you need any more testers? I've already printed out all the parts in PETG and PLA as specified in the PDF, I have recommended 17mm stepper motor, the gt2 belts, bearings, shaft, all the hardware required, and I have a substantial amount of various mechanical hardware just on hand (different sized gt2 belt loops, pulleys, idlers, a drawer literally filled with ball bearings of various sizes and matched tolerance shafts to go with them, etc. etc. I used to be really into robots so I have a lot of crap laying around =P) so I could probably fairly easily test any variants that might use slightly different hardware if that is at all needed.
I also designed my own extruder holder for the Flexion extruder a while back for the MK2S, and used that for a while, so I am definitely no stranger to this sort of thing. And if something doesn't work, I make it work and have fun the entire time I get to do that.
Basically, is there a more recent version than the files on thingiverse? If so, I want in :D. I'll happily give you very thorough feedback and reports on any issues/bugs I encounter.
It sounds like you might not be interested in more testers at this point, so I understand if I need to wait for public update like everyone else. I thought I'd ask before I assembled the version on thingiverse, and just in case you were interested in another tester.
Anyway, very cool design, and great CAD skills. I'm impressed.
Opublikowany : 22/06/2018 11:59 pm
JLTX
 JLTX
(@jltx)
As of Beta, everyone can be a tester. All info should be on the TV link. I update it as I go now. I would love your feedback. You can PM me on discord. I am working on some new goodness.
Opublikowany : 25/06/2018 2:33 am
JLTX
 JLTX
(@jltx)
I put up a video on Thingiverse to show better handling of flexible filaments.
Opublikowany : 04/07/2018 5:29 am
Steve_AU
(@steve_au)
I've got it printed, I'm still trying to find time to go to the bearing shop and get the 105's. I had a couple lying around but they had flanges on them, which pushed the filament guide out of place.
I also realised after the fact that the filament sensor holder (and the extruder gear holder swing) should probably be printed in something black, I printed everything in prusa orange. Is a very long 3mm bolt enough to throw through the extruder gear or does it need to be the 3mm shaft? I'll have a dig around town here and see what I can find.
Opublikowany : 05/07/2018 2:22 pm
JLTX
 JLTX
(@jltx)
It’s a 5mm shaft. I listed a couple options in the assembly instructions. Misumi can make one for you with flats.
Opublikowany : 06/07/2018 12:16 am
Steve_AU
(@steve_au)
I'm no expert at these things but this looks pretty cheap and fit for purpose. A Dremel or similar will cut it down to size pretty easily.
I had a look at Misumi Singapore again (I'm in Australia). 8 months ago couldn't register to purchase stuff (without a business number), but now I can. The shipping cost adds $65 USD, so it's not really an option.
I'll still try to find something local, I imagine I could just cut up a cheap Philips screwdriver.
Opublikowany : 06/07/2018 12:13 pm
JLTX
 JLTX
(@jltx)
Yes, my first was hacked from a 100mm rod like that. Worked fine.
Opublikowany : 07/07/2018 5:29 am
JLTX
 JLTX
(@jltx)
added new feature. see post here: https://shop.prusa3d.com/forum/general-discussion-announcements-and-releases-f61/do-you-want-your-filament-sensor-to-work-with-any--t23002.html
Opublikowany : 13/07/2018 3:27 am
