RPI Zero W not booting
daSpud
(@daspud)
I tried this https://help.prusa3d.com/en/article/prusaprint-rpi-zero-and-octoprint_2180 and got nothing on the wireless so I got a mini HDMI adapter so I could see what was going on.  I used the USB micro port to supply power.  The micro SD card imaged and verified perfectly (according to the program).  I was wondering why recommend a 16GB disk when the process is complete I had 12 GB of unformatted area.Changed the 4 lines and put in the root password and booted. https://www.screencast.com/t/TvNCmyBd8Q is what I got.  IT says unable to mount root file system.
Best Answer by Diem:
Kernel Panic is usually caused by a bad uSD card.  After verifying did you dismount it properly?
Reinstall the uSD and try again.
Publié : 17/08/2021 2:22 pm
The RPi Zero W is NOT recommended and is specifically called out as NOT SUPPORTED for OctoPrint
Are you getting the boot errors even when powering the RPi with a proper dedicated power supply?
The RPi Zero looks like a really neat solution, but even the Prusa knowledgebase you linked to notes that it's underpowered. There are a number of reasons beyond video problems with using the RPi Zero W directly mounted to the Mk3, and the developer of OctoPrint has gone to great lengths to specifically recommend against it.
I don't understand why Prusa won't take that page down. The Zero causes a lot of heartbreak and wasted time. I get it: The Zero is very cool to play with. It's just not the best fit for this use.
Publié : 17/08/2021 4:04 pm
Publié : 17/08/2021 5:21 pm
1 personnes ont aimé
daSpud
(@daspud)
Some progress
Thank you.  It looks like maybe I did not because windows complained when I inserted the disk to reflash.
It is curious that it booted and went through and adjusted everything and I was able to connect using the v4 ipaddress.  When I powered it on again it only listed v6 addresses but I was able to connect using octopi.local.
Then I put it in the printer and cannot connect to the network so I am thinking there must be a soldering error where it is not getting power.  Will continue to check on that.
As to the power of the Zero.  I only wanted wireless connection and I like the idea of integration of the board.  One big drawback I see is that I cannot connect a video cable to see the boot progress (or lack of it).
Publié : 17/08/2021 7:02 pm
