Revo six temperature failure
Emanuele
(@emanuele)
I installed the revo six kit on my prusa mk3s+ and after a month the printer gave MAXTEMP error above 230 °C. I replaced the revo six heather core, but now the hotend temperatures don't match the actual temperatures. Temperature read from the printer 200° Temperature read from the measuring instrument 185° , Temperature read from the printer 230° Temperature read from the measuring instrument 210°, Temperature read from the printer 250° Temperature read from the measuring instrument 230° , Temperature read from the printer 270 ° temperature read by measuring instrument 240.° I wrote to the producer, but he ignored me. I followed all the setup guides but the result is that I don't really know the exact temperature of the hotend. Do you know solutions? Thank you
Opublikowany : 04/12/2022 2:31 pm
RE: Revo six temperature failure
This should just work.  There is something bigger wrong with your printer, in my opinion.  I have installed two of these - one on a mini and one on an Mk3s.  They worked perfectly.
Opublikowany : 05/12/2022 11:24 am
Netpackrat
(@netpackrat)
There's been plenty written about Revo heater core failures here and elsewhere.  From what I have read E3D has been good about replacing the failed units, but it's not 100% clear whether they have actually solved the problem yet.
https://www.printables.com/@Netpackrat/models
Opublikowany : 05/12/2022 11:47 am
I guess that is possible.  I have three and have not read about them or seen one.
The max temp was a thermistor issue.
Opublikowany : 05/12/2022 11:50 am
