Revo Nozzle Stuck
3DCoded
(@3dcoded)
Revo Nozzle Stuck
I recently installed my Revo Six and have been printing fine for a few days. I have done several nozzle swaps with no problem. Now, when I try to remove my 0.25mm nozzle, it won't budge. I tried using pliers and it doesn't work either. I even tried heating it to 180C, which also does nothing. Is there any way I can remove my nozzle without damaging anything? I have already properly unloaded the filament. Any help would be appreciated.
Opublikowany : 19/10/2022 10:11 am
RE: Revo Nozzle Stuck
I would contact e3D.
Opublikowany : 20/10/2022 10:47 am
1 ludzie polubili
3DCoded
(@3dcoded)
I am currently trying to contact E3D, but since they are in GMT, and I live in the US, the time difference slowing down the communication.
Opublikowany : 20/10/2022 4:50 pm
That is understandable.  I am using a REVO and have not had this issue.  What filament?
Opublikowany : 20/10/2022 9:41 pm
3DCoded
(@3dcoded)
I am using Prusament PLA, and Hatchbox PLA.
Opublikowany : 20/10/2022 11:14 pm
sdc888
(@sdc888)
Were you able to find a resolution to this? I just ran across the same issue (nozzle is totally stuck). Thanks!
Opublikowany : 28/11/2022 3:13 am
3DCoded
(@3dcoded)
Posted by: @sdc888
Sorry for the late reply, I was able to contact E3D and after trying to clean the nozzle with tweezers and other methods, I just asked for a new nozzle and heater and they sent me a free replacement and a tracking link with no questions asked. I came across this issue with my new Revo heater and nozzle and I was able to remove it at printing temperatures (215C). I have not have the issue again since. Hope this helps.
Opublikowany : 28/11/2022 12:10 pm
I have not had the issue after 100+ hours printing on my Revo.
Opublikowany : 28/11/2022 12:14 pm
sdc888
(@sdc888)
Thanks have a ticket open will see what they say  - Did you use a tool or something to remove when it was at printing temps?
Opublikowany : 28/11/2022 2:19 pm
3DCoded
(@3dcoded)
Posted by: @sdc888
I removed the silicone sock while cold and then used pliers (you have to squeeze very hard) to unscrew it when hot.
Opublikowany : 28/11/2022 2:20 pm
3DCoded
(@3dcoded)
This started happening to me again, but I was able to resolve it by removing the sock, preheating the nozzle, and using pliers to unscrew partially. I noticed that this usually happens after printing flexibles (flexibles seem to really like sticking to my Revo nozzle) or when a blob shoves molten filament between the nozzle and HeaterCore.
Opublikowany : 29/11/2022 5:23 pm
sdc888
(@sdc888)
Thanks for this - will give it a shot!
Opublikowany : 30/11/2022 12:30 am
Jon@Studio17o7
(@jonstudio17o7)
I had that happen to me last week, and at the request of E3D support, dissembled it and tried to get it unstuck with pliers - which broke the ceramic and as a result E3D told me it was not their fault.  Since it was destroyed anyway, I tried channel locks as it was an Obxidian nozzle which isn't in stock ANYWHERE.  Will not budge, completely fused,
I replaced the heater core, reassembled and have run several test prints which went ok until my obxidian .4 wouldn't feed on a filament swap.  I was able to unload the filament and switched to a brass.6, which seemed fine although it seemed 'off' when I screwed and unscrewed it - just didn't feel right so I removed it and installed a brand new .25.  I've never used that fine a nozzle, so I did a 1st layer calibration just to see what it looked like and it came out perfect.  All seemed well, so I setup a sample (35 minute) print, made sure the first 2-3 layers were good and went to bed.
This morning I get up and find it had gummed up and raged all the pieces into a clump before stopping the print and waiting for attention.  No idea what triggered the clump, but I've found that Revo's seem to pick up a lot of goobers as they print and I have to brass brush them after most prints.
The nice thing was the print stopped before it went too far and it popped right off.  I decided I liked the .4 results better than the .25 so I went to remove the nozzle to swap it out.  F*ing thing is fused to the heater core.  AGAIN. I can't get it off even sitting here on my desk disassembled.
I'm reaching out to e3d right now, but I don't know what I will do if they try to claim it was my fault this time.  I'm out potentially 3 of their expensive nozzles and potentially two heater cores.
Opublikowany : 15/06/2023 3:13 pm
thebbb
(@thebbb)
Happened to me after printing TPU. What worked for me was heating up to 260C, then use a 10mm wrench on the Revo "base" and use pliers on the nozzle.
Opublikowany : 07/01/2025 2:51 pm
thebbb
(@thebbb)
So when I finally got my nozzle out, I noticed a lot of black crap on the nozzle (see photo).
I measured the thickness of the "dirty" part of the nozzle, was 6.03mm. Measuring my clean nozzles gave a value of 5.96mm. Apparently, the layer of filament residue was just thick enough to get the nozzle stuck in the Revo base. I contacted Revo, they recommended cleaning the nozzle with a small brass brush or a paper towel. I ended up cleaning the nozzle with very find sand paper (P800), nozzle looks like new now, measure 5.97 and fits perfectly again.Cleaned nozzle
Opublikowany : 16/01/2025 6:29 pm
Jason Lim
(@jason-lim)
I have a similar problem. My 0.4 mm revo nozzle is stuck tight. The only way I can unscrew it is by cranking the temperature to max (300 C), and I have to grab the nozzle super tight with pliers, and I'm only able to unscrew it by a tiny bit. I've stripped all the grooves because I didn't grip the nozzle tight enough the first time. The last I printed with before it got stuck was with a gray Elegoo filament. After that, it's been stuck. There's probably residue between the nozzle and the base. Note that I've been printing without those colorful socks, which I did not know were essential for heat blocking. I've already contacted E3D, and im still waiting on the hotend part to come in. However, i still need to print stuff, and I'm scared to print because I already unscrewed it a little bit, so I don't know if a blob will leak. Do you know how long it took you to take out the nozzle and clean it?
Opublikowany : 21/04/2026 3:41 am
Jason Lim
(@jason-lim)
Update: I fixed my printer. Turns out, whenever I turned the nozzle, I was also turning the heat sink, so it wasn't unloosening at all. I'm embarrassed that I unscrewed it the wrong way, which got it stuck to the heat sink in the first place. I figured this all out after disassembling, and then I heated up the nozzle while it was hanging by the wires, then unscrewed it in the correct direction with a pair of pliers. Glad to find out there was no gunk on the nozzle, and I can easily switch out nozzles like before. I'm still going to have them order me a new hot end replacement just in case. All this stress because I unscrewed the nozzle the wrong way.
Opublikowany : 21/04/2026 9:57 am
