Review: Cheap MK52 Print Surface
I bought a few of these in black and orange to test on my printer. I tinkered with them for the last two weeks and I have to say I am impressed but will caveate that with a foot note.
Highlights:
  • Aplication: Goes on easy with little to no bubble.
  • Filaments tested: I tested with with Hatchbox PLA, ABS, and PETG. I also did test prints with Prusa PETG and PLA. It really does stick well. The caveate is with PETG. It sticks a little too much and with PETG, I ruined one print and had to sand off some reminants. I would compare the results to BuildTak. I did find that I could retard adhesion with PETG with gluestick.
  • Cost: $3
  • Reccomend: I would recomemnd it as a cheap
  • Link: https://www.aliexpress.com/item/1pc-Prusa-i3-MK3-MK52-Sheet-Heat-Bed-Platform-3D-Printer-Buildplate-Black-Sticker-Sheet-For/32901822760.html?spm=2114.search0104.3.1.7c862eeen15t5G&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_10130_10890_5730315_10547_319_10546_317_10548_10545_10696_453_10084_454_10083_10618_5729215_10307_538_537_536_10059_10884_10887_100031_321_322_10103,searchweb201603_1,ppcSwitch_0&algo_expid=d56c8c58-5ca0-4750-8200-fec8456e4a9d-0&algo_pvid=d56c8c58-5ca0-4750-8200-fec8456e4a9d
  • I love this stuff!
    Opublikowany : 28/12/2018 3:29 am
    Re: Review: Cheap MK52 Print Surface
    Highlights:
  • Cost: $3
    Opublikowany : 28/12/2018 3:55 am
    Martin_au
    (@martin_au)
    Are these the same as the faux buildtak often found on Wanhao i3 plus printers and similar?
    If so, that stuff works pretty well. Sometimes adhesion is a bit too high, but on a flexibed that's probably not that much of a problem.
    Opublikowany : 28/12/2018 4:02 am
    Mustrum Ridcully
    (@mustrum-ridcully-2)
    Highlights:
  • Cost: $3
    did you use the steel sheet from them as well and if so was it flat with sharp edges smoothed?
    https://www.aliexpress.com/item/-/32948155660.html?spm=a2g0s.13010208.99999999.262.72a13c00PA0AXY
    Opublikowany : 28/12/2018 4:05 am
    Yes, I used their smooth sheet - I put PEI on the other side and used a deburring tool on the edges.
    Opublikowany : 28/12/2018 5:11 am
    I think so. I have a sheet of that to test next.
    Opublikowany : 28/12/2018 5:14 am
