Raspberry 4 with Octopi and MMU
PHerz
(@pherz)
Miembro
I am not a technical person... at all.   I got my Octopi working with my MK3S+ thanks to this video
However, I cannot get it to change filaments in my MMU. I am hoping someone out there has an idea on how to do it.
What does happen is, it ignores the filament change with the attached error messages, and just continues as a 1 filament print.
Attachment removed
Respondido : 15/08/2021 12:29 am
Miembro
Problem
Did you solve your problem?
Respondido : 23/08/2021 12:01 am
PHerz
(@pherz)
Miembro
Continuing problem of Octopi and mmu
Hi,  no I have not solved this problem yet.  I found a plug-in that might work, but, I have not gotten it to work yet
Respondido : 23/08/2021 12:12 am
Miembro
MMU2S
I just assembled a new Mk3S+ and will add an MMU2S but will waist on the octoprint till I see you have had success.
Posted by: @pherz
Respondido : 23/08/2021 12:56 am
Ruud
 Ruud
(@ruud-3)
Set your hotend and extrude tap.
Hi i think you forgot to setup the "hotend & extruder" tab in your printer profile in Octoprint correctly.
Set this to :
Nozzle Diameter - the Nozzle you use, normally 0.4 mm
Number of Extruders - set this to 5 so that Octoprint knows that there are "5 colors" to use with the MMU2S
Shared nozzle - Check this option and Optoprint will known that you use one extruder for the multi color use of the MMU2S.
Hope this solves the problem for you.
Respondido : 23/08/2021 8:35 am
1 les gusta
Miembro
Check
Posted by: @ruudgosens
Set this to :
Check this and let us know because that would cause it not to work.
Respondido : 23/08/2021 8:44 am
ShRTee
(@shrtee)
MMU Setup Octoprint
Set this to :
Will try this too.
Hope it solved all.
Respondido : 23/08/2021 9:59 am
ShRTee
(@shrtee)
MMU Plugin
What plugin was this ?
Respondido : 23/08/2021 10:00 am
Ruud
 Ruud
(@ruud-3)
Mmu2filamentselect
After setting up your printer profile in Octoprint you can use the Mmu2filamentselect plugin to select the filament you want to use on you MMU2S.
This only works if you have the print sliced in  PrusaSlicer with the printer "Original Prusa I3 MK3S & MK3S+ MMU2S Single" option selected.
Respondido : 23/08/2021 11:50 am
1 les gusta
PHerz
(@pherz)
Miembro
MMU plugin for Octoprint
The plugin I got was https://plugins.octoprint.org/plugins/mmu2filamentselect/ I have a print to finish and some reading to do and will get back to answering this forum in a few hours
Respondido : 23/08/2021 1:48 pm
PHerz
(@pherz)
Miembro
MMU/Octoprint Plugin
In PS 2.3.3 I selected Extruder 3 for this print. Then I exported it to Octoprint . In OP it says it is Tool #2 (and I get the regular error message) but it prints Filament #1
The 2nd pic shows how i have the plugin setup. I am having trouble showing this page, so I will make a 2nd post and keep thhe same Title
Respondido : 23/08/2021 3:31 pm
PHerz
(@pherz)
Miembro
MMU/Octopi Plugin
Respondido : 23/08/2021 3:35 pm
PHerz
(@pherz)
Miembro
MMU/Octopi plugin Solved
YES!  RUUD-3
Thank You
Respondido : 23/08/2021 3:51 pm
Ruud
 Ruud
(@ruud-3)
Happy Printing
Nice that the problem is solved.
Tool 2 in OctoPrint is Filament 3 on your MMU2S. Don't forget to add in your mind 1 to the OctoPrint tool when you chose your filament. Happy printing.
Respondido : 23/08/2021 3:59 pm
