random layer shifts / horizontal lines on my prints - only occurs from time to time
Hello all,
I have 4 MK3S+ with MMU2S that I use to print the same parts all day (most of them are cylinders).
The latest firmware have been installed on those: 3.13.2 for the mk3s+ and 3.0.1 for the MMU2s.
I use prusascliver 2.7.1 to slice the models.
The prints are connected to a Raspberry pi compute module 4 and a multi-instance of octoprint 1.9.3.
The parts are all PLA.
I can print flawlessly for days and sometimes, like yesterday, I get very strange horizontal lines on my prints as you can see in the pictures.
This time it created lines across 3 printers. Which IMO confirms it's not a Z-axis or nozzle issue.
I've looked at the forum for clues but nothing fits my case.
I can give you more details if you need some.
This is very frustrating because each time i run a print I fear this issue, which isn't caused by bad design or slicing on my part...
Can you help please? 🙏
RE: random layer shifts / horizontal lines on my prints - only occurs from time to time
Bumping this thread because I too would like an answer. I've had a similar issue that looks just like that happen to me a few times. At first I thought it was due to some test settings I was using to maximize flow, but it happened a couple more times after I returned to more or less default print settings in an effort to troubleshoot it. Then it just kind of stopped happening. As far as I'm aware, I haven't made any changes to the machine and I've since dialed in my high-flow settings for my CHT nozzle. Point being, I can't seem to link anything I've done to the occurrence of the issue.
Also adding my experience here. I updated my MK3S+/MMU2S to the 3.13.2 firmware in November. Every print longer than ~3 hours experienced major layer shifts that ruined the parts. I cleaned and lubricated the X and Y axis rods and re-tensioned the belts using the Prusa tension app. I tried another four prints or so after this and still experienced the same layer shifting issues on every print. I downgraded back to the 3.12.2 firmware and have not experienced another layer shift since (approximately 200 parts printed since).
This is definitely an issue with the 3.13.2 firmware.
in version 3.13.3 they fixed " Ghost layer shifts". Short summary: In firmware version 3.13.2, the XY axis currents were incorrectly configured and they were not switched to running currents after homing. This is now fixed. I currently have the same problem of horizontal line mid print. I will try to update the firmware. Hope it will fix
