PT1000 high-temp question
rustyshackleford
(@rustyshackleford)
I've got a MK3S with a Mosquito hotend and a PT1000. It works flawlessly below 300C, prints are perfect and everything works as it should. When I try to print PC at 300C, the hotend heats up and when it reaches 300C, it stays at exactly 300.0 for the duration of the print. I'm pretty sure that the hotend continues to heat up, because it takes 1-2 minutes after the print ends for the temperature to come back down from 300. When I modified the firmware, I changed the temp_sensor_0 setting to 1047 for the PT1000 and then changed the maxtemp setting from 305 to 400. Is there another firmware setting I missed that would cause the printer to stop reading anything higher than 300 and continue heating the hotend?
Ce sujet a été modifié il y a 5 years par rustyshackleford
Publié : 14/09/2021 11:21 pm
2 personnes ont aimé
rustyshackleford
(@rustyshackleford)
Update
Just to check that there isn't something else happening that I'm missing, I re-sliced the file and changed the temp to 298C. This time it behaved as expected, printing beautifully until it warped off the bed and I had to cancel the print. In these images, the top pieces were printed at 300C and the bottom at 298C (though, clearly the 300C print was far higher at the end... basically producing a smooth pool of melted plastic on the topmost surfaces).
These were printed about an hour apart using the same spool, same PrusaSlicer settings, everything the same except the temperature.
Publié : 15/09/2021 1:19 am
Hi Rusty.
standard Mk3 series printers do not use PT100 sensors.
Are you sure you have a PT100? these normally need an amplifier/interface board to work with the Mk3, and I believe they require modified firmware!
As far as I understand 300C is the limit for a Semitec 104 gt-2 thermistor, which is usually used on a prusa mk3 printer.
I believe Slice engineering offer a high temperature thermistor, to replace the standard Prusa thermistor, and to the best of my knowledge, this also needs revised firmware.
Publié : 15/09/2021 1:22 pm
rustyshackleford
(@rustyshackleford)
Thank you! To clarify, it is a PT1000, not a PT100. It does not require an amplifier but it does require modifications to the firmware. What I'm asking is whether anyone else has encountered similar issues when making this switch. I believe I updated what was needed in the firmware correctly but due to this odd 300C behavior I'm guessing I missed something Prusa-specific.
More background I should have included: I've just upgraded from the stock V6 setup to a Slice Mosquito hotend using the Slice 50W heater and the Slice PT1000. They did not have the high-temperature thermistor in stock and the PT1000 is supposed to work with just some minor firmware updates as described in my first post. Here is Slice's documentation on updating the firmware:
https://support.sliceengineering.com/portal/en/kb/articles/how-do-i-update-my-firmware-to-be-compatible-with-the-rtd-pt1000
Publié : 15/09/2021 1:53 pm
does your thermistor table have entries for temperatures above 300C (Appropriate for the PT1000)
Publié : 15/09/2021 4:46 pm
rustyshackleford
(@rustyshackleford)
Ah - thanks, you may be right. Here are the relevant sections from thermistortables.h in the 3.10.0 firmware. It does look like it stops at 300. I'll add a 350 row and see if that solves it. For anyone else reading this at a later date, a separate file called Configuration_adv.h defines "thermistorheater_0" as "temp_sensor_0". So the change in the Configuration.h file to modify temp_sensor_0 from 5 to 1047 changes the relevant lookup table in thermistortables.h from 5 to 1047.
// Pt1000 and Pt100 handling
// Rt=R0*(1+a*T+b*T*T) [for T>0]// a=3.9083E-3, b=-5.775E-7
#define PtA 3.9083E-3
#define PtB -5.775E-7
#define PtC -4.183E-12
#define PtRt(T,R0) ((R0)*(1.0+(PtA)*(T)+(PtB)*(T)*(T)))
#define PtRtNew(T,R0) ((R0)*(1.0+(PtA)*(T)+(PtB)*(T)*(T) + (T-100)*PtC*(T)*(T)*(T)))
#define PtAdVal(T,R0,Rup) (short)(1024/(Rup/PtRt(T,R0)+1))
#define PtLine(T,R0,Rup) { PtAdVal(T,R0,Rup)*OVERSAMPLENR, T },
#if (THERMISTORHEATER_0 == 1047) || (THERMISTORHEATER_1 == 1047) || (THERMISTORHEATER_2 == 1047) || (THERMISTORBED == 1047) // Pt1000 with 4k7 pullup
const short temptable_1047[][2] PROGMEM = {
// only few values are needed as the curve is very flat
PtLine(0,1000,4700)
PtLine(50,1000,4700)
PtLine(100,1000,4700)
PtLine(150,1000,4700)
PtLine(200,1000,4700)
PtLine(250,1000,4700)
PtLine(300,1000,4700)
#endif
Publié : 15/09/2021 5:16 pm
Has that worked for you?
Publié : 16/09/2021 10:51 am
rustyshackleford
(@rustyshackleford)
It appears to have worked, though I haven't printed anything yet. I just set the nozzle temp to 305, then 310 yesterday and each time it stabilized and read temperatures greater than 300 with some +/- fluctuations as I'd expect. I will have time to actually print again this weekend. Thank you for your help with this!
Publié : 16/09/2021 10:57 am
SeldonPrice
(@seldonprice)
Membre
RE: PT1000 high-temp question
Rusty, I would be willing to pay you for your help and knowledge on helping me alter the firmware for my Caribou 320 (Prusa clone company). I cannot get an SE high temp thermistor either, and need this machine to run ASAP. Any help would be greatly appreciated.
Thank you for your time and this article. I got a little ways but I cannot get the firmware to validate without error.
Publié : 24/01/2022 7:13 pm
rustyshackleford
(@rustyshackleford)
Sorry Seldon, I'm probably the last person you want helping you with this. I fumbled around with the Arduino software a few times until I got my printer working, but I am by no means an expert or even proficient. I would start with the following link. It was extremely helpful the few times I had to update my firmware for the Bear frame upgrade, E3D Volcano, and then Mosquito.
https://github.com/prusa3d/Prusa-Firmware
Publié : 25/01/2022 2:21 am
MileHigh3Der
(@milehigh3der)
Really interesting.  With E3d launching their high temp REVO models, I’m looking to do something like this- and probably a lot of other people will too. Thanks
Did you do anything to the bed to get it to go hotter?  Will the standard sheets from Prusa survive 350 or 400C materials?
Ce message a été modifié il y a 3 years par MileHigh3Der
Publié : 16/09/2023 9:40 pm
Darragh
(@darragh)
Membre
Sorry if I am performing a bit of necromancy here but although I believe the Arduino toolchain is now deprecated you could follow some of the steps in this article by Slice Engineering.
Updating my Prusa firmware for the Slice Engineering RTD Pt1000
Publié : 03/01/2024 11:03 am
1 personnes ont aimé
daveaz
(@daveaz)
Membre
Tangential thermistor question here.  I purchased a high temp thermistor 450 degrees,  on ali express that was made for the prusa mk3s printer. This is the listing I just found this on AliExpress: $0.79 | 1M Thermistor Temperature For High-Temperature Filaments 450 Degrees Hotend For Prusa MK3S 3D Printer https://a.aliexpress.com/_mM72hsF
I thought I would be able to use it on my all metal cr10s hotend but when I asked the vendor about marlin firmware settings, they had no idea what i was talking about.  Anyone have any idea where i might be able to find the specs for this thermistor or the correct marlin thermistor setting found in config.h?
Publié : 27/05/2025 12:46 am
Wnglok Lo
(@wnglok-lo)
Membre
Is there are other way to do it? My Arduino IDE has fail to verify for some reason.
e:\download\Prusa-Firmware-MK3\Firmware\configuration_prusa.h ^~~~~~~~exit status 1
Compilation error: stray '\' in program
Publié : 11/07/2025 4:17 pm
SciPrint
(@sciprint)
Should we add some defines to read the value from a yaml file? Also does the Core One L still use the 4k7 pullup resistor?
Publié : 06/01/2026 8:25 pm
