PrusaPrint and RPi zero W
Paulywog
(@paulywog)
Installed PrusaPrint to RPI Zero W with Etcher Utility, edited the octopi-wpa-supplicant.txt with Notepad++ for my wireless network.
With a network scanner should I be able to see the Pi even though I don't have it plugged into printer yet,  I am powering through the 5v port on the side of the Pi ?  It do not see any new network devices and my router starts them at .100 for the last ip part.
Opublikowany : 02/09/2019 4:36 pm
91d3on Mining
(@91d3on-mining)
RE: PrusaPrint and RPi zero W
Posted by: @pkoepnick
Yes, when I set mine up I wanted to test it before plugging it into the printer. I powered the PI up with the standard USB cable. It connected to my wireless network and I was able to see an IP for it in my router.
Did you uncomment the entire block and make it look like this?
## WPA/WPA2 secured
network={
ssid="Prusa Research"
psk="topsecret"
Did you also comment/uncomment your correct Country further down in that config file?
Opublikowany : 17/09/2019 3:36 pm
