octoprint won't stay connected
philip
(@philip)
test
Respondido : 19/03/2021 3:22 am
philip
(@philip)
RE: octoprint won't stay connected
octoprint won't stay connected. I can't paste the logs without getting a security warning and deleting everything I posted. Each of the 5 times I retype this it has gotten shorter.
error is too many consecutive timeouts.
yes rpi is enabled. I have tried 2 cables and all 4 USB ports on the pi
Esta publicación ha sido modificada el hace 5 years por philip
Respondido : 19/03/2021 3:28 am
philip
(@philip)
There was a communication error while talking to your printer. Please consult the terminal output and octoprint.log for details. Error: Too many consecutive timeouts, printer still connected and alive?
philip
(@philip)
I'd LOVE to give you more information but I'm really quite tired of getting
A potentially unsafe operation has been detected in your request to this site
Your access to this service has been limited. (HTTP response code 403)
If you think you have been blocked in error, contact the owner of this site for assistance.
Block Technical Data
Block Reason: A potentially unsafe operation has been detected in your request to this site
Time: Fri, 19 Mar 2021 3:29:35 GMT
Respondido : 19/03/2021 3:30 am
1 les gusta
could you try ZIP compressing the information that you are trying to attach.
the chances are that you are trying to use a format that is not available on the forum
Respondido : 19/03/2021 10:34 am
Dan Rogers
(@dan-rogers)
I do wish that connecting with Octoprint didn't stop a print in flight.
Respondido : 24/03/2021 12:04 am
towlerg
(@towlerg)
@dan-rogers
A few more details?
Respondido : 24/03/2021 8:06 am
Dan Rogers
(@dan-rogers)
Yeah sure.  When you start up octoprint and access the UI in a browser and then hit connect button.  It connects no problem.  But as soon as it connects, the printer "resets" and anything you are currently printing from SD is stopped, no way to resume.
I wish for a printer setting that says "do not reset/reboot on serial port connection"
Respondido : 24/03/2021 2:50 pm
I think the printer will reset on any USB connection, not just OctoPrint. Edit: Apparently it's an Arduino thing. Without it, flashing new firmware is difficult.
You definitely don't want to be doing anything that will reboot or reset OctoPrint while in the middle of a big print!
Respondido : 24/03/2021 3:22 pm
@philip
If you transfer your data via USB cable, you must disable RPI. When transferring data via GPIO, RPI is enabled and no reset is triggered anymore.
Respondido : 24/03/2021 4:00 pm
