Octoprint no longer connect to MK3 after updating from 1.3.6 to 1.3.12
Zooraw
(@zooraw)
Octoprint no longer connect to MK3 after updating from 1.3.6 to 1.3.12. I can connect to the rpi zero w via SSH and web. I tried to roll back by doing a re-image of the SD card but it behaves the same way.
Error message:
There was a timeout while trying to connect to the printer
Postato : 29/12/2019 6:54 am
Zooraw
(@zooraw)
RE: Octoprint no longer connect to MK3 after updating from 1.3.6 to 1.3.12
2019-12-29 19:27:15,803 - octoprint.util.comm - ERROR - Unexpected error while connecting to serial port: AUTO IspError: ''Timeout'' @ comm.py:_openSerial:2661 (hook default)
Traceback (most recent call last):
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 2661, in _openSerial
serial_obj = factory(self, self._port, self._baudrate, settings().getFloat(["serial", "timeout", "connection"]))
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 2623, in default
port = self._detect_port()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 2604, in _detect_port
programmer.connect(p)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/avr_isp/stk500v2.py", line 34, in connect
self.sendMessage([1])
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/avr_isp/stk500v2.py", line 108, in sendMessage
return self.recvMessage()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/avr_isp/stk500v2.py", line 119, in recvMessage
raise ispBase.IspError("Timeout")
IspError: 'Timeout'
Postato : 30/12/2019 6:14 am
Jason_M
(@jason_m)
i have exactly the same issue. bug needs to be fixed.
updated to the latest octoprint and cant connect.....
Postato : 03/01/2020 12:22 am
which device (dev) do you use?  (dev). Do you have a backup of the entire SD card with v 1.3.6? RPI enabled (see LCD, connection over GPIO=on, USB=off)?
cableconnection from the pi to the einsy ok? USB or GPIO? Baudrate ok (115200)?
Postato : 03/01/2020 12:38 am
also take a look here: https://octoprint.org/blog/2019/09/10/new-release-candidate-1.3.12rc1/
otherwise you could also contact gina (developer from Octoprint).
Postato : 03/01/2020 12:59 am
Jason_M
(@jason_m)
I managed to figure out the issue.
I found a lost by another user having the same issue on GitHub.
I had my palette2 hooked to the pi.
The pi wouldn’t connect to the printer.
disconnected the palette 2 and all is good.
I have installed the palette 2 and canvas plugins now and will test again that the pi can still connect to the printer.
jason.
Postato : 03/01/2020 1:25 am
You can get support for palette 2 here:
https://support.mosaicmfg.com/hc/en-us
There is also a forum there. The product is relatively new and there is still some potential for development inside.
I am not familiar with palette 2, but maybe you can get help here:
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-others-archive/mk3-and-palette/paged/2/#post-66869
Postato : 03/01/2020 5:23 pm
Breacor3D
(@breacor3d)
Posted by: @devin-g
Error message:
I am having the same issue on two 3b+'s connected to mk3's, newest update has disabled any connection via GPIO (power via usb) and can only connect over usb. This seems to be a pretty bad bug. Please advise anything i can do to remedy this, as it was working before the 1.3.12 update
Prusa XL 5THPrusa MK4. Atomic Slate Gray CfPETG partsPrusa Mini+ Kit (Atomic Perfect Purple) with Bondtech IFS and Revo MicroVoron 2.4 350*350*500Voron Trident 250Voron Trident 350Ender3BeltKit (heavily modified)Many other small upgrades for these printers as tinkering never ends.
Postato : 30/01/2020 4:54 am
@j1999t
Maybe you can find here your answer:
https://community.octoprint.org/
Postato : 30/01/2020 5:32 pm
