Octoprint MK3S+ settings
What printer profile settings should I use in octoprint for the MK3S+ ?
Best Answer by K7ZPJ:
The MK3, MK3S and MK3S+ use the same settings for the Octoprint profile.
thanks for the link.
I already found that page but was wondering if mk3s and mk3s+ have the exact same profile settings in octoprint.
RE: Octoprint MK3S+ settings
This support article covers the configuration of Octoprint for use with the MK3S+. https://help.prusa3d.com/en/article/octoprint-configuration-and-install_2182
I have a fairly well modified MK3S with a SuperPinda probe, Bondtech extruder, and Mosquito hotend, along with the Slice High-temp thermistor. I also run Bondtech's branch of the printer firmware. So mine is definitely no longer a MK3S, but not a MK3S+ and I use Prusa's default printer and slicing profiles without a problem.
I've modified the printer profiles that correspond with the nozzles that I have to include the Octoprint connection so I can send directly, but outside of that I've not altered a single thing. I pick the appropriate material profile and away I go.
Aaron
