OctoPrint
david.h61
(@david-h61)
OctoPrint
Installed Octopi on a PI 2 model B. I can bring up the web interface but when I try to connect it will not connect to the MK3. Any suggestions what can be wrong? When it is trying to connect the LCD on the MK3 changes and the fans come on.
Posted : 31/03/2018 5:02 pm
Bytor
(@bytor)
Re: OctoPrint
What are you connection settings?
- 1st "printer" TIKO 3D
- 2nd PRUSA i3 MK2S with MMU v1
- 3rd PRUSA i3 MK2S
- 4th PRUSA i3 MK3 with MMU v2- 5th PRUSA i3 MK4 (upgraded from MK3) with MMU v3 (upgraded from…
Posted : 01/04/2018 2:31 am
ed
 ed
(@ed-3)
Re: OctoPrint
My experience has been that having the baud rate at auto causes issues, that being said ensure your baud rate is 115200...
Posted : 01/04/2018 3:22 am
imod.systems
(@imod-systems)
Re: OctoPrint
Are you using a fresh OctoPrint image or the PrusaPrint OctoPrint image? If you're using the PrusaPrint image and have the Pi connected via USB you will get boot loops because the default connection setting is set for serial, not USB.
Posted : 01/04/2018 3:59 am
robert.b52
(@robert-b52)
Re: OctoPrint
Turn off RPI from the Prusa menu or it won't connect via USB.
Menu->Settings->RPI Port
Set it to Off.
Posted : 02/04/2018 4:30 pm
david.h61
(@david-h61)
Re: OctoPrint
Thanks
I will try this tonight.
Posted : 02/04/2018 6:51 pm
david.h61
(@david-h61)
Re: OctoPrint
Thanks for the help
I was using auto detect when i selected the speed connected.
I do get this error when starting a print
Posted : 07/04/2018 7:13 pm
Shoey
(@shoey)
Re: OctoPrint
Thanks for the help
Are you using a skirt or brim that falls outside the print area?
Posted : 07/04/2018 7:26 pm
neil.e
(@neil-e)
Re: OctoPrint
Thanks for the help
This is expected with the default Octoprint settings. It's because the purge/priming line prints outside the defined print volume. You can just disable this check in Octoprint by going to Settings > Features and un-checking Enable model size detection and warn if model exceeds print bed.
Posted : 07/04/2018 7:38 pm
Zingabopp
(@zingabopp)
Re: OctoPrint
A better fix is checking "Custom bounding box" in your Printer Profile under "Print bed & build volume" and setting the Y min to -3 for the purge line.
Posted : 07/04/2018 7:54 pm
david.h61
(@david-h61)
Re: OctoPrint
Thanks
I saw that but was not sure what it was. I should have tried it.
Posted : 07/04/2018 9:40 pm
neil.e
(@neil-e)
Re: OctoPrint
I originally tried that and still got bounding box errors so just gave up and used the hammer solution of flipping off the check. S3D ensures my stuff is within the bed bounding box already, I don't need two checks.
Posted : 08/04/2018 12:06 am
Mert Kışlakçı
(@mert-kislakci)
RE: OctoPrint
I am using Toshiba w-04 wifi sd card. I read your article on the form stating that this card can be used as an ftp server, but I could not set the card as ftp. I want to use the card as an ftp server via Windows 11 with a static IP, can you please help me with this. What should my config file be like? What steps do I need to do?
Posted : 13/01/2025 7:42 pm
