OctoPi need cooling
iftibashir
(@iftibashir)
OctoPi need cooling
Raspberry Pi Model 4B running OctoPi
If used only for a TouchUI for general printer tasks, as well as OctoLapse, does the Pi really need additional heatsinks or cooling fans, or are you running yours without?
Postato : 15/12/2022 9:48 pm
JimB
 JimB
(@jimb)
RE: OctoPi need cooling
A heatsink and/or fan is not mandatory for the RPI 4B.  If it starts to get too warm, it will throttle the clock rate, which will affect performance.  It could also shorten its life.  But since a 3B is more then enough for octopi, you'll probably be ok.  Make sure there is plenty of air circulation so the heat can get out.
Postato : 15/12/2022 10:18 pm
Extra Fox
(@extra-fox)
I run my Pi4 with heat sinks and a cooling fan. Cheap insurance.
Aaron
Postato : 16/12/2022 6:29 am
Hello
(@hello)
I would recommend at least a heat sink
Postato : 16/12/2022 8:00 am
RandyM9
(@randym9)
+1
Posted by: @extra-fox
Postato : 17/12/2022 4:46 am
1 persone hanno apprezzato
