NozzleX - How to increase default filament temp?
sroghen
(@sroghen)
HI,
I have just upgraded to the E3D Nozzlex 0.4 on my MK3S+ to print with more abrasive filament. I read i will need to increase the default temp for all filament by at least 5-10 degrees.
How do i do that? Is it on PrusaSlicer or the ML3S+?
Thx
Ce sujet a été modifié il y a 5 years par sroghen
Publié : 18/10/2021 1:26 am
in Prusa Slicer, you can select a profile, modify the print temperature and save the profile as a new name,
then in future select the new profile name.
I am using 'Nozzle Z' which is hardened steel, and I have not found a need to change the print temperatures with either PLA, PETG or TPU
(every printer is slightly different, try printing  a small sample model with normal settings before you create a new profile)
Publié : 18/10/2021 6:48 am
