NOSE Bioprinter mod question
a.khan.4
(@a-khan-4)
Hi everyone,
I'm a biologist working on stem cell development - full disclosure, I know next to nothing about 3D printing but am very down to learn...
I am in the process of building a Prusa i3 MK3s to adapt to make the bioprinter reported here:
https://www.sciencedirect.com/science/article/pii/S2468067218300877
https://nydus.one/wiki/index.php/Open_Source_Bioprinter
I'm in the process of building the frame and had a question. Do you think it is worth building the kit fully and testing it with the plastic extruder, and then go on to mod the printer? Or would you recommend not fitting the extruder and just proceeding with the bioprint build.
Please forgive my ignorance - any and all opinions and thoughts welcome.
P.S. If anyone from Prusa reads this - your kit is kind of amazing. I've never come across such well constructed instructions and easy to navigate kit. Very well done!
Napsal : 12/03/2020 3:39 pm
RE: NOSE Bioprinter mod question
Hi A-Khan-4,
I would suggest building the printer as a plastic printer first and ensuring everything works as expected, before modifying it.
I would also highly recommend lubricating the linear bearings during assembly, rather than waiting for a maintenance breakdown...
regards joan
Napsal : 12/03/2020 5:00 pm
a.khan.4
(@a-khan-4)
@joantabb
Thanks for taking the time to respond - I will do as you say. Including lubricating the bearings!
Best wishes
Abs
Napsal : 12/03/2020 5:41 pm
rmm200
(@rmm200)
On lubrication - you will get a potful of suggestions on what to use.
This is a light duty application, and pretty much anything is better than nothing.
If you use SuperLube, look at a lubricator cap like this:
https://www.thingiverse.com/thing:1128781
Of course, to print one you have to have a 3D printer working. Then it is too late to lubricate during assembly.
Maybe, just this time, have someone print one for you.
Napsal : 12/03/2020 6:02 pm
1 lidem se líbí
a.khan.4
(@a-khan-4)
@robert-rmm200
Thanks that's very helpful =)
Napsal : 13/03/2020 8:52 am
