Increase Z axis height
jake
 jake
(@jake)
Hi
Increasing my z height with a new frame.  Wondered if anyone has swapped the lead screws out on their stepper motors?  Normally the lead screws are just glued onto the stepper rotor.  Anyone done it?
Ta
Opublikowany : 05/08/2021 9:00 am
Lead screws
You might get better results by just buying new ones.
Opublikowany : 05/08/2021 9:38 am
jake
 jake
(@jake)
lead screws
Hi
I've got new lead screws.  I want to swap them.
Opublikowany : 05/08/2021 9:48 am
good luck
Posted by: @jake
Hi
Keep us posted.  I have no idea how you would do this on Prusa steppers.
Opublikowany : 06/08/2021 12:28 am
jake
 jake
(@jake)
Easy
Hi
Easy to do.  Take out the 4 screws and split the casing.  Remove the rod and bearings.  Make a note of the amount of rod sticking out past the lower bearing bush, 6mm in my case.  Put some cardboard or other protection around the rotor.  Put the lead screw in a vice and clamp sole mole grips to the rotor.  Give it a twist to break the glue and remove the rotor, bearings and bushes from the lead screw.  Then glue the rotor on the new lead screw with some epoxy and re-assemble.
Opublikowany : 06/08/2021 10:40 am
