Hyperpixel 4" Touchscreen + LCD + Raspberry Pi4 for Octoprint and OctoDash Prusa for MK3s+
rockethorse
(@rockethorse)
I posted a how to guide for my remix of other MK3S+ control panel + Hyperpixel 4" screen + Raspberry Pi 4 for OctoPrint and Octodash:
https://www.prusaprinters.org/prints/69731-hyperpixel-4-touchscreen-lcd-raspberry-pi4-for-oct
The post includes a pretty thorough "how to" setup guide.
I've really been enjoying this setup, and I hope this inspires other remixes or is of benefit to the community.
Note: I received a series of private messages from a user who has attempted to replicate this build, but experienced “low voltage” error messages from OctoPrint that they have been unable to resolve, despite valiant effort. I have not experienced low voltage errors, but this appears to be a risk in this build.
Questa discussione è stata modificata 5 years fa 2 tempo da rockethorse
Postato : 30/07/2021 4:20 pm
2 persone hanno apprezzato
Utenti
Awesome
I really like this mod.  I might have to add it to my printers.  I have had a few low voltage errors with my Pi 4s.
Postato : 31/07/2021 12:02 am
addohm
(@addohm)
Were you bored?
I dont see the point.  Everything you see and do on your 4" touchscreen, assuming you have the fingers of an infant, can be seen\done on the prusa display.
Postato : 04/08/2021 11:00 pm
Utenti
Hmm
I think I agree.  I still want to try it.
Posted by: @addohm
Postato : 05/08/2021 1:25 am
forceStatus
(@forcestatus)
Sleep mode
With this addition have you implemented a way for both screens to go into a sleep/powered down mode. I understand the 8bit  original screen is either on or off according to power switch and the power saving is negligible.  But still I want this functionality.
Postato : 06/08/2021 11:19 am
rockethorse
(@rockethorse)
The hyperpixel touchscreen just makes everything easy. Yes, it is an unnecessary luxury!
I use the hyperpixel on almost every print. My printer is nowhere near my computers, so I send print jobs from prusaslicer directly to octoprint, then go to the printer, select the sheet I need for that print, change the filament, then select the print file from the hyperpixel. It's just so easy with the touchscreen.
Also, moving the X, Y, and Z axis is so easy with the touchscreen. Also, selecting pre-heat mode is so easy.
These are all minor points but they add up for an improved experience.
Postato : 06/08/2021 3:11 pm
djgabriel2004
(@djgabriel2004)
amazing mod
Thanks for putting that together.
I just finished my kit and I will be installing this  during the weekend.
Postato : 11/08/2021 7:49 pm
Maxcore
(@maxcore)
Crasy mod
Thx for sharing this your job was amazing !
Postato : 13/08/2021 1:50 pm
Hell
 Hell
(@hell)
@rockethorse: Does this Hyperpixel and Octoprint combination allows you to scroll through all the print files on the SD-Card and to see a 3D view of a file before (!) starting a print (same behaviour as on the Mini+)?
Postato : 08/11/2021 8:35 pm
rockethorse
(@rockethorse)
RE: Hyperpixel 4" Touchscreen + LCD + Raspberry Pi4 for Octoprint and OctoDash Prusa for MK3s+
Not sure about the mini behavior because I don't have one. With this setup you can scroll through all the filenames of prints sent to octoprint, and when you click in each you see a preview thumbnail of the print if you have thumbnails enabled on the slicer and thumbnails activated on octoprint.
Postato : 08/11/2021 8:42 pm
